Beta testing has progressed, at least one tester has successfully programmed his regulator and calibrated it with the GUI system.
A new version has just been sent to beta with a few new features.
Here is the Change Log:
0.10 20090816 version sent to beta test
0.11 20090816 added code version support to handle multiple code version files
in the same dir, also added this ChangeLog. Code Version is NNN, started
with 099 since previous version was 0.98<something>
Moved bulb data out to a "bulbdata.csv" file.
Added Programmer Selection and Port. Select port "usb" for usb programmers.
Added support for USBtinyISP from
www.adafruit.com/usbtinyisp.
Select "avrisp2" for Atmel's AVRISPmkII, and select "usbtiny" for the
www.adafruit.com programmer. Select port "usb" for both.
Restored the interface level from the configuration file.
0.12 20090816 fixed Low Bat error when inputting RMS and Battery DC Reading is
zero or blank. The Battery DC Reading must be either higher than the calibration
voltage, or it must be zero. It should be accurate or it should be left
blank.
