SOLUTIONS: Length & Clip
Hello all. While I'm on this forum a lot, I don't post much unless I feel I can contribute something useful. So here goes:
First off, like many of you have said, while this light is intended for your keychain, I've heard many comments stating the the length with the QD attached is simply longer than many of us would have preferred, especially since its's essentially one long, rigid, stick on your keychain. I'm in this boat as well. While I love everything about this light (especially the emitter), my only nagging reservation has been the way it carries. This is what I did: (try not to gasp)
That's right... I drilled a (tiny) hole in the back end of it and added a split ring. The hole is above the inner groove where the ball bearing detent is. This way I can remove the split ring and go back to the QR setup later if I change my mind. But for now, I'm finding it to be perfect in its shorter form.
For those who have asked about a clip:
This clip works perfectly. Super secure and solid, as if it were made for it. Looks good, too. It's from my Olight i3.
