Pulk Sled Hot Tenting Sub Zero Winter Adventure.
Woods Walker
The Wood is cut, The Bacon is cooked, Now it’s tim
New England woods.
I am too busy for long dissertations so for the most part will let the photos do the talking. Maybe a short description here and there. The cold snap looked nice. Planed on Friday through Tuesday but got Saturday through Tuesday. Good enough.
Go!
Camp First night.
The "Sacred Bacon".
Next day needed wood and water.
Not really enough snow to melt and getting water was a challenge. In fact a bit dangerous.
Watering hole.
Getting kinda cold. The cold air pooled up in the valley. The overcast sky turned crystal clear at night creating a radiational cooling event as I expected.
Hungarian meats.
Field testing new kit for upcoming ultimate sub 50 dollar solar charging bugout/hiking/whatever system.
Fire being sucked up the pipe by the draft.
Stack robber.
Another day and it's cranking cold clear. The best part was the wind. Not crazy but enough to add an edge to the brisk temps.
The water situation was getting a bit sporty as the rivers (two in the area) freeze up.
The old watering hole frozen over but only an inch so found a rock (not frozen to the ground which was a pain) and smashed a hole. The rock slipped and can be seen on the bottom. A few feet past this spot the water deepens and is moving fast. If the ice gives way a person cold be sucked under. So never walk out on the ice in a situation like this. You risk death.
Wood for the win! My camp runs on wood, water and power. The wood and water are interchangeable as the wood stove is keeping my water liquid and potable.
The liner drapes to the ground adding a double wall which is both anti draft and helps create and inner bubble of heat.
Home made red lentil soup.
On Tuesday this ship is ready to sail
This time packed the sled with a lower center of gravity.
Here are two videos which are part 1 and 2.
Thanks for looking!
markr6
Got my pulk (same one) loaded and ready. Trouble is, the snow all melted!! Will be dragging it over frozen ground and should be fine only going about 3mi total.
Good times!!
LeanBurn
Alberta
Pretty cool. I like the vids and how you illustrated the simplicity of winter camping when it comes down to it. Once you have the gear it is very simple and seemed to be quite satisfying.
miyagi
Honolulu, HI
Fantastic! Always enjoy watching and learning from your vids. Regarding the bacon oil, isn't that really bad for you? You mentioned you need it for this expedition, almost for survival. Can you explain more on this? Get less hungry?
Woods Walker
New England woods.
In sub zero weather the body can consume 6000 or more calories a day. It all gets incinerated. There is one pro. Yea hardly need to go number 2. LOL!
Woods Walker
New England woods.
Thanks. It is comfortable but yea don't want to leave the sleeping bag in the am. LOL!
zespectre
Shenandoah Valley
I used to do a lot of winter camping in my younger days. I often found that weather just at or just below freezing was harder to deal with than when you got below the 25 degree mark. I think it has a lot to do with the moisture in the air. Sadly I never had a stove-in-the-tent setup to try, I nearly always set up tarps in a classic "bakers tent" configuration with the fire facing it. Probably not nearly as warm as your setup, but surprisingly cozy unless the winds really decided to kick up. I know I used more wood than you did though.
Woods Walker
New England woods.
You are correct. 36F give or take with sleet/freezing rain/cold rain is probably with the notable exception of tornado, hurricane or lightning strike the worst weather in terms of risk IMHO. The water transfers heat around 26 times faster than air so it's not hard to see why people die in it. I have camped in that as well and it's best to hunker down. Sub zero F is easier to deal with. As luck would have it here is a video of me camping with a similar setup in exactly those conditions.
Woods Walker
New England woods.
Oh snap I forgot about the cellphone pics.
I glossed over the pulk sled travel part but that had some challenges. Nothing major but did roll the sled a few times fighting the stone walls.
Always give the suck a thumbs up. This way it sucks less.
Then again the suck also gets a thumbs up cuz it's a wonder to look at.
Wood!!! The first night I found a tall thin maple sapling. In one shot I got most of my wood for the night. As I setup in the dark sweated up a bit from fighting the pulk the fuel was welcome. Sled full of processed wood is like money in the bank.
The inner workings of the DIY heat exhanger can be seen via glow as the secondary combustion ignites unburned fuel in the smoke. The 2 A-Frames and "H" baffle plate.
What's on Caveman TV?
Channel 1. Flames.
Channel 2. Coals.
Sub zero and in my birthday suit as letting the layers of clothing air out on the shelter clothes line. Another use for fire. Heat the shelter, cook food, boil water and dry clothing.
Steam coming off the water as the radiational cooling event I was hoping for occurred. Like a fire in reverse. Nature/entropy abhors a differential.
Lots of calories.
zespectre
Shenandoah Valley
Oh hell yeah, that is exactly what I mean, and that feeling when the fire finally catches and you know you are gonna get to dry out your clothes :)
