2xTrinity
Niether will be very good. Let me propose an experiment:Personal note: walking through a darkened hallway using a Fulton light with a red filter - I could not read the rooms marked in red. Could not see the red lettering at all. I knew it was there, but I couldn't see the lettering at all.
I may have to pop a vein to test the theory about which shows blood better, blue or red.
-Trevor
Let's say you have a drop of red blood, and a drop of black ink on a white surface in a dark room:
With blue light, blood will appear black against a blue background. It will be impossible to distinguish from black ink. With red light, the blood AND the paper will BOTH appear red, so the black ink will appear black, all else will appear red. With a white light, it will be possible to distinguish all.
Doesn't make any sense. True UV light (eg, shorter wavelength than 365) will be almost invisible, and near-UV light that IS slighlty visible is often used in conjunction with a yellow filter to eliminate its visibility. The UV light itself then actually hinders contrast.Say, more interesting photos. I think I know what you are getting at now. The frequency of light amplifies the difference in materials. I believe I've heard of something like this in detecting fake antiques or repairs that aren't visible in normal light. The UV doesn't make the glue glow, it just makes it show up by contrast. Does that sound close?
The key point here is that near UV will fluoresce things like bodily fluids very weakly, not "brilliantly" like a fluorescent highlighter ink.
Here's another important point: Most "UV" Leds emit in the 380-400nm, which doen't cut it for two reasons:
1) these longer wavelengths are much less effective causing object to fluoresce in the first place.
2) the light itself is much more visible (masking any fluorescence that does occur)
I actually work extensively with a 365nm laser. As the laser is monochromatic, it is much less visible than 365nm UV LEDs or fluorescent lamps which have significant amount of energy in longer portions of the spectrum. I notice all sorts of fluorescence. The light itself is just barely visible, but If I place my hand in front of the beam, my skin fluoresces bright green (as does dust/skin collecting on mirror surfaces etc).
However, this effect is far less dramatic than putting a piece of white copier paper in front of the beam (which has blue fluorescent dye that reacts to UV)
