The following is a list of measured frequencies for various flashlights. This will be updated as people contribute.
Jetbeam CL-E (AA): 73 Hz [Strobe mode is 8 Hz]
Jetbeam C-LE v1.2 (AA): 315 Hz [Strobe mode is 8 Hz]
Fenix L0 multi-level series (AAA): 100 Hz [Strobe mode is 8 Hz]
Fenix L2D Series (2AA): NO PWM [Strobe mode is 8 Hz]
Fenix P1D Series (123a): NO PWM [Strobe mode is 8 Hz]
Huntlight FT-01-XRE (2x123a): 186 Hz [Strobe mode is 8 Hz]
Photon Freedom (2x2016): 185 Hz
FluPIC v2.2: 195 Hz
SafeLight SuperBright (9V): 1149 Hz
Inova Microlight: 95Hz
ALX-233C 3xC 3W: 128Hz
Streamlight Tasklights: (3AAA, 1AA) 189Hz [Strobe mode is 3 Hz]
LED Logic Striker-VG: 150~180 Hz [Strobe mode is 9 Hz]
Inova Microlight: 97 Hz [strobe mode is 3 Hz]
Freedom X-light micro: 185 Hz [strobe mode is 11 Hz]
HDS B42: Burst: no PWM, Primary: no PWM, Secondary: 1161 Hz, lowest level: 448 Hz
LiteFlux LF2: 7670 Hz
Nuwai 654C and 352: 9910 Hz
JetBeam MkIIX: 120Hz [12/14/5 strobes]
Jetbeam MKII (no X) 95 Hz [strobe mode is 14 Hz]
Rexlight 2.0: 94 Hz [strobe mode is 10 Hz]
Dexlight X.1: 120Hz [12/14/5 strobes]
Dexlight X.V: 73 Hz [strobe mode is 8 Hz]
Jetbeam JET-u (AAA): 315 Hz [Strobe mode is 8 Hz]
Photon Photon (AA): 197 Hz
[The strobe numbers are for the intentional pulsting mode of the flashlight, not related to PWM]
For those of you who don't know what PWM is, it's "Pulse Width Modulation". Instead of the flashlight circuitry dimming the LED by supplying less power, it "pulses" the emitter on and off rapidly. So instead of supplying 10% of the power 100% of the time, it's supplying 100% of the power 10% of the time.
The assumption here is that the eye has enough persistence of vision to not notice the pulsing on and off.
The "dislike" of PWM is either (1) the frequency is too low, and persistence of vision isn't enough to remove the flicker by the viewer, or (2) there is relative motion between the flashlight / environment / viewer, in which a pulsing light becomes more obvious.
Consider the case of two flashlights which are waved in front of a camera on extended exposure. The top one (Fenix) has a slower PWM frequency. The pulses on and off are more obvious to the user. The bottom one (Huntlight) has a faster frequency. It's less likely to be objectionable to the viewer.
Again, the lower the frequency (Hz), the more noticeable the pulsing is.
How can frequency be measured? Well, if you don't have an oscilloscope, I have an easier method for you. If you have a digital volt meter with a "Hz" or frequency setting, hook an LED up to the leads and shine the flashlight on the LED in a dimmed setting (one step below maximum). LED's just happen to produce a small voltage when light is shined on them (somewhat like a stereo speaker can work like a microphone). Here is a picture of the setup, in which the meter is reading ".186 k Hz" (=186 Hz):
I found that the LED is not sensitive enough for measuring lower light levels. Perhaps a solar cell would work better(?)
The goal of this post is to collect together PWM frequency data for different flashlights for member reference.
Comments and suggestions welcome
FluPIC v2.2: 195 Hz
