Q on the lanyard that comes with the Raw
starstreak
Oahu, Hawaii
How strong it is? I know it uses like a steel string to loop the flashlight. Did anybody have theirs break over time?
It looks the same as the Wee one?, which was not too strong - mine broke with regular wear use. :caution:
The BT lanyard we supply with all Lummi lights is Strong.
It is made from stainless steel wire, I forget how many strands but its allot.
If you were to put on your finger a pull I would suspect it could cut right through with enough force. Think Cheese wire :faint:
Only reason for it to fail in normal use is if it were to get cut / frayed. This as with any lanyard requires periodic checking & replacement if necessary.
