Quality Charger for AW C cells
BlackICE
Colorado
I'm in the process of building a 2C Mag 5761 using AW C cells.
I'm trying to figure out what the best charger would be. My main criteria are finding one that's easy to use and more importantly will charge safely. Something in the $150 or less range.
Here's the one's I'm looking at:
Cellpro 4S
Tenergy
BC-6
iCharger iC6
I'll most likely be using magnets to charge the cells individually. Any suggestions on which would be best?
Will
I'll let someone else comment on the chargers, as I do not own any of those. I will say you might want to add the Triton or Triton jr. to your list though. My reason for posting is to suggest that you take a look at this method of connecting the charger to your batteries. Happy modding. :wave:
I have this charger and it does the job well.......amperage and mv's are all adjustable, and it will also charge lith-ion, lipoly, as well as your car battery......it can charge two packs at different rates as well.....which i find useful-its like having two seperate chargers.
Yes, I was originally thinking of adding the Triton/Triton jr. to the list. The reason I didn't was because the others have the option to add a 12 VDC power supply for about $30.
Are the Tritons significantly better than the others on the list? I wouldn't mind going that route if there was a simple/clean way to set them up for AC.
Do the AW cells light a 5761 bulb? Thats impressive if they do.
I would say BC-6, I have never used one, but I checked one out at a race and it was pretty nifty. Might be overkill for just some C cells though.
Yes, from what I've read the AW cells with a 5761 make an excellent compact light with about 900 torch lumens. I'm still gathering the parts for mine.
The BC-6 looks like a great charger. I like the fact it's comes ready to go with AC current.
AW C's work great w/the 5761 lamps. I'm running mine with AW's multi mode switch and charge with a Triton.
I have two PSU's on my bench for powering up the Tritons. In the field a car battery works well.
I thought they would not even power a ROP HO.
Thought they had protection circuits kicking in around 4.5-5 amps.
I'm not sure at exactly what point the protection circuits kick in. But there are numerous people running this setup successfully with a softstarter.
Aw's softstart design ramps up the initial load allowing a reduced draw as the lamp stabilizes instead of the usual max amperage kick start then lower draw. Others are modding switches w/NTC's to do the same thing.
Not an expert and only have a couple of 5761 assemblies under my belt, but I haven't had a good battery go bad or lamp instaflash yet.
You might be confusing AW's C-cells with that KD battery pack that barely lights up a ROP-LO. AW's will easily power up the ROP-HI.
We've noticed some variance in AW's C-cells where some of the cells will trip their protection when powering the 5.5A 5761. Too little resistance in the light will trip the protection circuit also.
Gary
To the OP...
I've a BC-6 on order. Should be here this week. The fact that it can charge anything that's rechargeable was a big selling point for me. It will also balance charge multiple cells. Along with the AC/DC power, I saw it as a trifecta.
However, $180 (with the thermocouple, a few charging harnesses and the like) is a bit much for 'just a couple' of C-Cell batteries (NiMH and LiIon)...:sick2:
Gary
i was just going off of the 5A limit in his sell thread.
To the OP...
I actually just placed an order today for the BC-6. It's true that it's overkill for just a couple C cells. Ultimately, I wanted a good charger that I could grow into with other projects.
