Good Morning,
I'm looking for a light that will replace my quark. Here are the most important aspects I need.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
__X__Up to $120.
3) Format:
__X__I want a flashlight (hand held/self contained).
4) Size:
__X__SMALL - No longer than 4.5"
5) Emitter/Light source:
__X__LED (Nichia 219 or XP-G2 Neutral)
6) Manufacturer:
Don't care
__X__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
__X__I don't care
__X__I want to illuminate my entire backyard or a campsite (150-300 lumens).
__X__SPECIAL NOTE: Burst/Turbo mode Category - (Why not?)
Not too tight or wide.
__X__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
__X__Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
___X_Less than 1 yard/meter (reading, other close work)
__X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__X__5-20 yards/meters (check out a noise in the backyard)
__X__30-50 yards/meters (I have a big backyard)
__X__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
__X__90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
__X__Very Important (Camping, Backpacking, Car Glove-box).
__X__I want a forward clicky (Helpful for momentary activation and signaling).
__X__I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
__X__I want a tail mounted switch (found on the majority of today’s high end lights).
MUST always have high or programmed mode on tight no matter how many times I press the tail switch.
__X__I want multiple light levels. (Some lights have 5-16 light levels.)
__X__I want a programmable light.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
__X__Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Water resistance
__X__IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
X In house (temperature/climate controlled environment)
X In my pocket
__X__Pocket/belt clip
Thanks guys!!!
__X__Up to $120.
3) Format:
4) Size:
6) Manufacturer:
Don't care
__X__I don't care
X In my pocket
Thanks guys!!!
