Quarks and EagleTac M2XC4 - personal impression with beamshots
Swedpat
Boden, Sweden
A few days ago I received my new package with flashlights from 4Sevens and EagleTac. I am not going to be more specific about all the functions or technical specifications but just share my simple impression of them.
Because I have been more and more "biten by the warm LED bug" two of the lights are in a, so called, neutral white version: Quark AA2 and EagleTac M2XC4. Apart from these I ordered a Quark123 cool because this model is outsold in the neutral white version, and a Zebralight H501. The both Quarks I chosed the regular version because I want it simple and tailstandable.
When I first read about the new 4Sevens Quarks models my expectations became high. And when I had received them it didn't take long time before I could state that they are an improvement compared to Fenix corresponding models. Though still not perfect, in my opinion. The better knurling is good, though I still wonder why the AA2 version has to be narrower in the mid section. When pressing the button with the thumb I have to quite hardly pinch the tube to prevent the light gliding forward. The narrower midsection combined to a quite large demanded force to press the button complicates the procedure. Nitecore D10 is a dream in this matter! Personally I would also prefer a slightly more aggressive knurling of the Quarks.
The beam profile of the new Quarks is just great, in this matter in par to my Fenix TK10. Practically no noticable artifacts or rings like with Fenix LD/PD models, just a bright hotspot with an even illluminated spillbeam. The beam width is slightly wider than Fenix which may be positive or negative depending of the personal opinion and usage. This makes the spillbeam to be slightly less intense than Fenix with narrower beams.
The very low modes of Quark I consider as a true advantage, who during some occations are very useful! For an example 9 lumens (of Fenix LD20), though it's a low output, is dazzling for reading a text at close distance with dark adapted eyes! Actually the lowest mode of Quarks of 0,2 lumens is fully adequate with dark adapted eyes for locate your self in a room when you don't want to draw attention. A runtime of weeks also may be useful in some case of emergency somewhere.
Colour rendition is something I have learned to appreciate. It's well known that the ability to see details of dark objects of , for example, brown, green and red colours, is superior with a warm tint than a cool one. Fenix TK20 has a nice and comfortable tint compared to the cool tints. But I don't really experience it as neutral, rather warm. I find the tint to be to the brown side, or more specific beige. But in the same way cool tints who alone seems to be very white, instantly when compared to an incan light are revealed to be bluish, I find Fenix TK20 to be like rose in comparison to as well Quark AA2 and EagleTac M2XC4.
Quark 123 is a very nice and small light, very similar to Fenix PD20, and it's the same as with PD20: I will not stop to be amazed of the light output such a small light produces. The handling is similar to PD20, but with the advantage of knurled bezel.
When read through 4Sevens site some day after I received the order I found that they offer 0,9-4,2V head in natural white, so I ordered it. Soon I will have as well the 123 model with the warm tint!
EagleTac M2XC4 is an impressive light with a beam profile reminding of a flower, because of the three reflectors. When comparing beamshots at a white wall this is very ugly and not at all in my liking. This light is designed for throwing with an intense hotspot, though the spill beam is very bright as well. If you can stand the beam profile design you will have a very useful beam, and I think the flower-like beam is not an issue at all out in the field and forest.
About the handling I find it's stable to hold though it could have been a slightly longer handle, I think persons with large hands can find it far to small. Changing between the brightness modes is easy done with a one hand operation with the rotary switch. This function could be much better, however. The rotary switch has no steps and you just turn it until you see the brightness changes to the prefered level. The space between the levels are not equally divided, and when turning from 300 to 665lm level it's very easy to pass it and accidently get the strobe, which is very close placed. The rotary switch I find is a very good idéa, but I wish it had been with distinct clicks to prevent accidently changing. And also with marks like Fenix TA models so you can see the brightness level before you turn it on when use the included tactical clicky. This clicky also could be better. It has a momentary on function, but when I want to use it momentary I find it easy to accidently turn it on constantly. You have to press quite long way until it turns on, and the step between momentary and constantly is quite close. At first I actually thought it lacked momentary on function because I missed it.
About the beam I prefer a perfectly rounded and even illuminated beam with a warm tint. I could not get both in this case, so therefore I chosed the M2XC4 in neutral white version instead of the M2C4. And I think I did the right choice. When shining with the highest brightness I just become amazed, so pleasant bright "milk-white" tint, I am sold! The neutral white is the future...:thumbsup:
Zebralight H501 is a new experience for me, which surely will be a light I bring with me wherever I travel. An easy operation, perfect flood light with three well suitable brightness levels of 3,3 - 18 and 96lm. And I reacted of how small it actually is. I don't find anything serious to complain about with this light.
After I received it I became aware that it's available in a neutral white too, with slightly lower output, but unfortunately not from 4Sevens, then I had of course chosed it instead of the cool white...
I hope these my personal impressions may be valuable though my somewhat faulty english. I will also post some comparison beamshots.
Regards, Patric
From left: Zebralight H501, Fenix PD20, Quark123, Nitecore D10 GD, Quark AA2 neutral white, Fenix LD20, Fenix TK20, EagleTac M2XC4 neutral white, Maglite 3D/Malkoff P7, Maglite MagCharger:
Nitecore D10 GD low vs Quark 123 moon, 1s vs 1/5s:
Fenix PD20 turbo vs Quark 123 max, 1/100s vs 1/500s:
Quark AA2 neutral white max vs Fenix TK20 turbo, 1/100s vs 1/500s:
Fenix TK20 turbo (150lm) vs EagleTac M2XC4 neutral white at 125lm setting, 1/100s vs 1/500s:
Fenix TK20 turbo vs EagleTac M2XC4 neutral white at max, 1/100s vs 1/500s:
The initial brightness of MagCharger is around 300lm, and therefore it could be interesting to compare it with EagleTac M2XC4 neutral white at the 300lm setting, 1/100s vs 1/500s:
And the same as above but with EagleTac M2XC4 at max:
Maglite 3D/Malkoff P7 vs EagleTac M2XC4 neutral white at max, 1/100s vs 1/500s:
VERY interesting to see the comparison shot between the TK20 and the 2AA Quark neutral.
Looks like the TK20 doesn't give up much, if any, to the Quark. If the Quark does out-lumen it, it must be in the hotspot because the spill on the TK20 looks brighter.
I'd be curious to see what the TK20 would do in an integrating sphere; rumor has it that the TK series are closer to out-the-front lumen, and Mr. Gman's tests seem to confirm this in the case of the TK11/TK10.
Thanks for your replies,
I think you are quite right. But when it comes to as well hotspot and spillbeam intensity Fenix TK20 outperforms Quark AA2. According to my ceiling bounce test Quark has a very slightly higher total output because the beam width is wider. However, You can't go wrong with none of them, in my opinion! ;)
Regards, Patric
This night I went out in the nature with four of my lights: Quark AA2 neutral white, Itp C6 Tactical my Impression of Itp C6 here, Maglite 3D/Malkoff P7 and EagleTac M2XC4.
Itp C6 and Maglite 3D/Malkoff P7 have very equal cool white tint, and the biggest difference was that the Mag throws better and has a wider beam.
The difference of colour rendition was significant: When I shined on the trees with the mix of green and autumn-yellow leaves the colours with the warm LED of the EagleTac and Quark appeared so natural and clear compared to the cool LEDs. The total performance with EagleTac was quite similar with 300lm mode as Maglite/Malkoff and with highest mode the EagleTac outperformed the Mag-Malkoff with the better colour rendition and brighter spill.
My suspicion about the ugly flower-shaped beam of EagleTac M2XC4 also became confirmed: out in the field it's not an issue, hardly noticable or annoying as it is indoors at a white wall.
Regards, Patric
last night I did the same: going to the forest with some of my torches. This time I took a D-mini EX WG tint (tint is relatively green) , a Zebralight H60w, a Nitecore Extreme WC/WD tint (my whitest tint, no green, blue or yellow!), A lummi Raw with a 5a tint and the M2XC4 with three of them. The NEX together with a red blinky light was my bike lighting. The Raw is my EDC and these two I used very little. Mainly I wanted to see the difference between the D-mini EX (MC-E) and the M2xc4.
I fully agree with Swedpat that when out in the forest, the warmer tints (5a and the like) are far better to see details and depth. After I parked my bike I took a strole and after 5 minutes or so I heard some breaking twigs and some leafes ruffle. So I turned off all the torches and stood still for a moment so I could hear where it was coming from. I was hoping it was a deer. The rusteling stopped and I decided to first check with my D-mini EX and see what animal was near me. this little MC-E really did light up everything in front of me! Wow. But the tint made everything looks greyish and green?! Sure, it was plenty bright but the grey was very unnatural and indeed, it was difficult to make out details. I did not see the wild boar untill it started walking again... even though it was only about 30 meters to the side. Then I turned off the D-mini and turned on the M2xc4. It was a world of difference. The wild boar was walking slowly past me at about 20 meters now and I pointed the M2xc4 at the sound it made and wow, there it was. It was so easy to follow the boar with this tint. I could clearly make out the animal against the foresty background! As it walked away from me I kept following it with both the D-mini and the M2xc4 and kept comparing the tints. If the boar moved, I could see it clearly enough (with the MC-E) but when it was standing still at about 40 meters I would loose sight of the boar due to the lack of colour (it just blended with the background) and with the M2xc4 I could easily spot it again.
The other difference I noticed: the floody nature of the MC-E is very very pleasant. It is as they say a wall of light. It's very comfortable to be able to have peripheral vision. The M2xc4 did just was it was made to do: throw with a nice sidespil and it did this very well indeed. It course, it is not as floody as an MC-E emitter.
When I was cycling back home, I was thinking, if the D-mini EX only had a warmer tint, this torch would rock in the forest together with the M2xc4 and the H60w!
Now I also understand why EagleTac is now listing the M2SC4 in a neutral tint. :thumbsup:
Thanks Fareast for sharing your experience!
You tell me good AND bad news. The good news is that also the textured reflector with the round and smooth beam I like will be available in the warmer tint. :twothumbs
The bad news is that I soon has to charge my creditcard again... :eek:oo:
But; I think I should wait until the rotary switch is improved with distinct and easy visible steps. I guess that will come before or later.
Regards, Patric
Looks to me like the Fenix blows the Quark out of the water.
Regards, Patric
I gotta say, I am also very tempted to get the warm MC-E version. I just gotta have a neutral MC-E torch!
When you get one before me, let me know how it compares! It seems we have a similar taste in torches. And if I were in your shoes, I would sell the h501 and get the warm version or even better the h60w.
Vi ses!
Hi Fareast,
I will tell my impression if I get a M2SC4, but I will not get it in this moment.
Today I received the Quark Neutral white head for my CR123 cool white Quark (which I ordered because the neutral white was outsold), and I can just say I like it better then the cool one.
My Fenix PD20 has now been replaced by it, and because I don't find any situation I rather would prefer the PD20 anymore, I likely will sell it.
About Zebralight H501 I am tempted to get it in the neutral white version.
Regards, Patric
