I am not sure if this belongs here or the battery forum, but will try it here.
Anyway, I had a second glow plug fail Friday last week and replaced it. My car would go from starting right up to having to grind the starter for it to catch, then it would have a miss for a few seconds.
Anyway, replaced that, so back to 4 glow plugs working in the 4 cylinder engine. Anyway, Tuesday I felt it again require me to grind the starter to get it started as another glow plug failed. I ordered 2 more at the local auto store. They do not sell bosch and the autolites have a 2 year warranty.
Come Thursday, a second plug failed and it would not start unless i did a lot of cranking and adding some ether.
Friday afternoon it would slowly turn over and not start. I decided to use my second jump starter device that hooks to the battery and is supposed to give 450 amps. Of course I also had a 200 watt model plugged into the cig plug from a few years ago I purchased to use for portable power. It works and hooked it up after I left my light on a few weeks ago as it seem to help me start up faster.
Long story short, the past 3 times I have started it, even with a new 850 amp battery from the 700 amp battery it had in it, seemed the jump starter
rated at 450 amps helped it to turn right over, where as nothing else would.
Not even a new battery with another 150 amps. The charging system seems to work as the battery voltage is 12.74 off.
Anyway, installed two more glow plugs and got one returned and two more on order. It started right up tonight just after the idiot light went out.
Other than that strangeness, I find with the new proper size battery for my mercedes 240d the lights do not flicker at a 40 hz rate like they did since Ive owned it. Plus at the adjusted jacked up idle, the lights do not dim slightly either at idle.
The idea of replacing the alternator has crossed my mind, but I aint rushing out to replace a 50 amp model with another 50 amp model. I want something 2 to 3 times that size.
