Question About LED Mini Strobes
Roy
Farewell our Curmudgeon Administrator
Granbury, Tx USA
I received my order of Mini LED Strobe lights from Countrycomm yesterday. Great fun playing with them.
Now I have a question....why do they not work in direct sunlight? If the lens of the light is pointed toward the sun, the lights go out. Put a shadow over the lights and it lights up and starts strobing. Anyone know why? Is the sunlight changing the properties of the LEDs somehow?
Re: Question Abou LED Mini Strobes
Photocell? I've never heard of one in bellybutton light, not even a "covert" bellybutton light, but it's not out of the question.
I'd take a look at the thing under a magnifier and see if there isn't some kind of light sensor.
Huh, interesting. Mine just shipped from Countycomm yesterday. I guess I'll wait and see...
daloosh
[ QUOTE ]
[/ QUOTE ]
My GUESS and already hinted at -
there is probably a light sensor built-in that is the strobing "mechanism".
When the LED switches ON there is enough light to trigger the sensor to switch it OFF - once OFF there isn't enough light to keep the LED OFF and it switches back ON again, and so on - hence the strobing.
But direct sunlight probably is bright enough to trigger this light sensor to prevent the LED from switching ON.
I'm guessing that the IC chip itself is photosensitive.
When I took my County Comm strobes outside in the sun a few days ago, I could make the red LED stay on, the blue LED stay on, or both LEDs stay off; depending on my timing of direct sunlight application.
I don't believe this is an intentional function, just an accidental or incidental one.
Yes, the IC itself is photo-sensitive. Some of those cheap dollar-mart watches also has the problem of stalling at direct sun light. That's because the IC was not protected properly /ubbthreads/images/graemlins/smile.gif
It's hard to imagine the photo-cell effect being by design on those cheap things. A 1W luxeon directly over the IC doesn't overload it, but it almost completely washes out the blue LED.
None of the components under the resin appear to be packaged.
I wonder if the red LED is more resistant to the effect due to lower Vf (or if it just doesn't wash out as easily as the blue)?
I didn't see any difference in bevaviour between the red and blue LEDs when I experimented with my strobe in the sun.
I think the IC is photosensitive; the LEDs themselves aren't.
When I exposed one of the strobes to my SureFire L5 at almost point-blank range, the strobe rate decreased (became slower) a bit (noticeably, but not a whole lot), but the strobing did not stop.
