Question about xenon bulbs
Flash_Gordon
NC USA
I just put them in and then wipe the glass down with alcohol. Even if you don't touch the glass using a glove or a tissue, you can't assume that the handler before you did not touch it. IPA is cheap and effective.
Mark
65535
*Out There* (Irvine, CA)
As long as they are IPA-ed after they are in the socket they will be fine. there is no guarantee they will blow but it's an avoidable risk.
litho123
Chicago Suburbia, IL
Ditto to what others have said.
After having had a couple bulbs shatter (I think it was from sloppy bulb handling) when I first started dabbling with "hotwire" lights, I'm now a little obsessive about bulb cleanliness!
If the bulb is ever exposed to possible touching, it gets wiped down before the head gets screwed back on.
I use 2"x4" cotton swatches moistened with Isopropyl Alcohol.
