<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by brightnorm:
In order to power an LED array that would generate the same total amout of light (lumens, candela, peak this or that, I don't know the technical terms, but I think you know what I mean) of say, an E2, would you really need less power than 2x123? <HR></BLOCKQUOTE>
As always: Yes and no.
1. When you need coloured light (traffic signal, car's rear lights) LEDs are unbeatable now for several years.
2. For white light it is a little more complicated:
If money is no issue, you may take 500 'S' grade Nichia LEDs (the best one currently) and power them very low. Then you take the most efficient regulator to match the LEDs and drive them very low at 1-2 mA each. Then you will get 25-30lm/W.
If you take the best halogen bulbs and drive them also with a regulator to keep them at the perfect working point and start them soft, you will get also some 25lm/W. You may get more, but then you have a shorter bulb lifetime.
So when using fancy electronics and lots of money, they will have about the same efficiency.
In real life, the E2's bulb will have some 12lm/W and the usually overdriven LEDs some 10lm/W (or maybe a little less) with fresh batteries.
But batteries are only freh for a short time and when they degrade, the incandescent bulbs get worse and worse while LEDs gain in efficiency.
The actual thing is, that all flashlights are bought with fresh batteries (and compared) at the shop, but used most of the time with not so fresh batteries.
3. Again and again: Your lights efficiency depends higly on your application. If you need a small tactical spotlight, a LED light will be of limited use (at least now). You need an incandescent light.
If you use it to light up a walking trail, an ususal LED's light distribution is almost perfect.
If your lighted objects contain lots of brown, yellow, red the incandescent's lower light temperature may improve it's efficiency by far. If they contain 'colder' colours, the LED light shows it's strength.
And the unit of interest is the luminous flux, or the 'amount of light' measured in Lumen. Depending if you put all your Lumen in a small beam or not, you get more Candela or less. It's like a garden hose. Assuming constant water flow (=Lumen) you may put it into a narrow jet or into a wide spray. The amount of water per second stays the same.
