I would suggest holding out for the leefbody option, 2x18650..
As for the turbo head... What I would do personally, is keep your eyes peeled for either a C-C leefbody, or C-M... and whatever you can get, grab it up, just make sure it is a 2x18650 length... If you get a C head model, then use a SureFire Turbohead from the KT1 or KT2 kits, if you get a M head, you will need a Millennium Turbo found in the KT4 kit(which will include a MN16 to run). Run a MN16 in there It will run in the 300 lumen range (SF ratings) on those cells. If you really want a true "350" Surefire lumens, (400+ torch lumen) then you might want to consider going with a Wolf-Eyes M90 13V system with the EO-13 from LF, or a M6 loaded with RCR123 and the HO-M6R, or some other method of getting a 3x18650 or 3x18500 size cell driving a 13V lamp...
Having said all that, I think you might be better off just building a 2C ROP with AWs C size li-ion cells. You can build the whole thing for probably less than the cost of the Surefire build, and be dishing out more lumens.
