here you go. this one he is holding is a Wolf-Eyes light but its the same as Pila lights. i can resend you the video by email or soemthing.
http://members.shaw.ca/iwonger/Wolf-EyesFlashlight.MPG
5-Mode 4 x LED Tailcap Switch Using:
A. Screw the 4 x LED tailcap on to the end, the head light will be constant-on, tailcap light off.
B. Screw the 4 x LED tailcap back off half turn, head light off; the tail 4 x LED light will be constant-on. Simultaneously the head light can be Morse on by depressing the tail 4 X LED lens and then the tail 4 x LED light will be cut off automatically in turn.
C. Screw the 4 x LED tailcap back off further, the tail 4 x LED light will be turned off; simultaneously the head light will be Morse on by depressing the tail LED lights lens.
D. Continue screwing the 4 x LED tailcap back off further, the head light will be turned off; simultaneously the tailcap light will be Morse on by depressing the tail LED lights lens.
E. Screw the 4 x LED tailcap back off further more, both the head light and the tail 4 x LED light will be lock-off to prevent activation
i copied all the above from thier site. saved me a few minutes typing all that out /ubbthreads/images/graemlins/happy14.gif
another thing to add to the above. when using the LED tailcap switch, everytime you press the switch, the LEDs will always turn on first. when you press harder the LEDs will turn off and the incan will turn on. you'll see it in the video.
