HI All,
I'm relatively new to the 123 battery world...so with that said, the Background:
Brand new early Christmas present: Fenix TA30
Purchased at exorbitant prices (3) Li-Ion Energizer 123 batteries. Two marked 8/09 and one marked 5/09.
Installed on Tuesday evening, 12/8
Total use on batteries: Maybe 1/2 hr total burn time with a mix between high, medium and low.
Symptoms:
Everything worked as expected until Thursday evening. The light was in my truck in cold weather for a few hours. I used it on medium and high for about 30 seconds to a minute, shut it off with the clicky. Went to click it back on and there was a flash, then nothing. I can not get anything other than a flash on the High and Medium settings, followed by going dark. On low, I get constant, steady light. The strobe also works. I cannot, however, switch between low to any other setting when the button is on nor can I start at medium or high and move to low and have any light. I have to start on low, click off, then on and then I get light.
There doesn't seem to be a problem with the revolving bezel, although there is some play at the end of travel on both sides. From some other posts regarding the TA30 on CPF, that may be normal.
Questions:
Is it possible the batteries are maybe going bad? Is this a normal sign that maybe one of the cells went bad?
Is there a problem with the light?
I don't want to return the light for warranty if it's just a battery issue, but I also don't want to drop the big buck for new batteries if that isn't the problem either. If this needs to go back, I'm going to consider asking for a refund and go with something that takes standard batteries (AA). If it's a battery issue for sure, I'm going to go for rechargeables (AW from 4Sevens).
Any help would be appreciated.
Tony
Symptoms:
Questions:
Tony
