Questions about Surefire C2 Centurion led
22hornet
Province of Antwerp / Belgium
Hello,
I'm considering a Surefire C2 but have the following questions:
- if I get the led version, can I still exchange the led module with an incandescent bulb? (P60)
- does the 80 lumens led version throw as well as the standard incandescent version?
- if I am getting it right, the same Surefire led module is also used with 3 cell Surefire models. So I gather I can use 3.7V rechargeables without any fear of damaging the light?
- Does a C2 battery tube accept rechargeable cells readily or is it too narrow?
Please help me out :candle:.
I am also considering getting the Malkoff drop-in 235 lumens as an accesory.
Many thanks,
Joris
Yes
No
Yes
17mm and under (single 17670, rcr123) batteries will fit, 18mm batteries will require the battery tube be bored out.
Hello,
Joris
I saved a little money recently by buying the C2 and P60L separately.
Great light BTW.
The difference between the C2 incan and LED versions is about $40. I'd go with the incan version and use that extra $40 toward the purchase of a Malkoff M60 ($60) if you want throw and output. It will blow the Surefire P60L away! Not to mention it'll have a much better tint.
