Subterranean13
- Joined
- Jan 29, 2008
- Messages
- 9
Hi, I'm very interested in building a battery pack of my own due to the difficulty and cost of getting hold of prebuilt packs where I am (UK) and also due to personal interest and involvement. However I have a few questions left to make sure I am doing this as safely and as practically as possible that I could not find through doing a search of these forums.
Firstly, I will only be making packs of 18650 cells in parallel; I will never have any cells or sets of cells in series. My idea is to use good quality LG 2600mah unprotected cells with solder tabs, with a protection circuit such as this one, all shrink wrapped. I will likely use 3 or 4 cells to start with, but I may think about larger packs later, again always in parallel.
I have heard from people making series battery packs that one problem is making sure each cell stays balanced so as not to allow other cells to overcharge or have other problems. Are there any similar issues when making a parallel pack like I am wanting to? So long as I make sure each cell is matched in voltage when I connect them together, is there any problems that may happen over time? If one of the cells starts to die, is the result likely to be catastrophe or simply a drop in runtime?
Any help or useful links you can give are appreciated. Also if anyone has done this themselves any first hand advice would be great.
