Questions installing DRL-1 in 2005 Ford Ranger
Lightdoctor
Got a question as to how to install a DRL-1 in a Ford Ranger while also modifying the front side markers to flash with the turn signals. Would I splice in the DRL-1 before or after the side markers to get the results I want?
Thanks
The DRL-1 should already do that if wired in accordance with the instructions. However, it won't flash the sidemarkers in opposite phase with the turn signal lamps. Opposite phase is only permitted in North America; most other countries require them to flash in synchronous phase with the turn signals when the headlamps or parking lamps are lit.
"The Emerald City" is Oz, then, right? So you're in Australia somewhere? Then you shouldn't have them flash in opposite phase when headlamps/parking lamps are lit. Or are you talking about the Queen City?
Seattle is also known as the Emerald City.
Maybe I didn't articulate properly. I'm trying to understand if I can use the DRL-1 for it's intended purpose and still be able to make the front side markers flash as well. I'm trying to figure out how best to wire this up? DS has on his site a written way (no schematic) of using the DRL-1 for side marker flashing, but doen't make clear if it still will work for the original DRL function as well.
Thanks
many new cars i see around have drl on one side shut off when that side turn signal is on, i'm not sure why, but my guess, you just wont see turns blinking with bright drl on. will your side marker be visible still with drl on?
My goal is to make the front turn signals work as DRL and also make the steady lit front side markers work with the turn signals. I'm trying to figure out how to proceed so as to get the correct results. DS' site shows how to modify the side marker wiring to go to flash mode, but that requires being able to ground through the turn signal filament. With the DRL unit installed, that would mean having to ground through the DRL unit to the turn signal filament. My question is, will that work?
Thanks
I think you're having trouble getting your question answered because it's a little ambiguous. That's because the DRL-1 module can be used for a bunch of different applications, not just adding DRL function to the front turn signals. One of these other functions is that it can be used to have the front side marker lights flash with the front and rear turn signals while also remaining functional as steady-lit side markers (when the turn signal isn't activated). That's a nicer alternative to the non-module way of making the side markers flash with the turn signals, because by using the module the side markers will always flash in phase with the front/rear turns, never in alternate-phase. If you use the non-module method, by putting the side markers' wires across turn signal + and parking light +, the side markers will flash in phase only when the parking lamps (or headlamps) are off. If you turn the lights on, the side markers will flash in alternate-phase with the turn signals, which isn't as good particularly in applicaitons where the side markers are also visible to the front.
If you want to use the DRL-1 module to have the front side marker lights flash with the turn signals, always in phase no matter whether the parking lights are on or off, the hookup instructions are in this article. If you also want to use the DRL-1 module to have a daytime running light function added to the front turn signals, you would need a total of two DRL-1 modules, because each module can only be wired up to do one function, not multiple.
If you are doing the non-module method of having the side markers flash, and installing a DRL-1 to implement daytime running lights, then the only real concern is how to hook things up so the side markers don't light up full time with the DRLs. That's not hard. You cut the side marker light's ground wire, then tap the "bulb" end of the cut wire into the vehicle's turn signal wire ahead or "upstream" of where the DRL-1 module gets put in line with the turn signal wire. So tracing the wire forward from the turn signal switch on the steering column to the turn signal light on the front of the truck, the tap-in for the side marker wire would come before the DRL module hook-in.
Don't forget to upgrade your bulbs for best results: 5702KA for the front turn signals (super long life for steady-burning daytime running service) and 6XW for the front side markers (7 candlepower instead of the stock 2 candlepower for maximum side-blinker effectiveness).
Thanks Scheinwerfermann, that is the answer I was looking for. I just wasn't sure if I could use DS' method of cutting the ground on the side marker and still have it work correctly with the DRL-1. As to lamps, I installed the Sylvania P3457AKDA lamp from Candlepower. I've found that the regular 'painted' bulbs don't hold up over time and the colorant burns off. As to the side markers themselves, I'll probably install for now some Osram W5W lamps that I already have.
Thanks
I figured it was Seattle (or, "the Queen City" as I wrote above).
The original question was a mite ambiguous, because of the difference in in-phase and out-of-phase (when parking lamps/headlamps are lit) operation.
I think I would prefer the out-of-phase operation when the headlamps are on, solely on the idea that it *seems* more attention-getting that way. Whether it really is attention-getting, and in a way where no ambiguity is introduced, I have no idea.
