I dont have the numbers you asked for
are you trying to shine a long distance outdoors?
If your goal is to find the custom light with the most throw, for the least money
skylumen.com has the RRT-01 with the WhiteOne LED.. its a beast! of a thrower,
without getting into lights that can literally burn a hole in your pants.
he also makes a triple
https://www.youtube.com/watch?v=UV691D4W2Zo&t=20s
And he can install tritiums in the tailslots!
iirc, malkoff uses reflectors and switches from McGizmo, with single LED.
They produce a tight throwy hotstpot, similar to HDS.
oveready uses triple optics, they produce a larger hotspot..
triples are more floody than singles.
look through these threads to get some more info
electronic ramping triple, you could be getting into the latest, most cutting edge LED light tech, for peanuts ;-)
https://www.candlepowerforums.com/vb/showthread.php?458503
examples of different LED color temperatures and CRI (Im a fanatic about using Nichia 219b LEDs)
https://www.candlepowerforums.com/vb/showthread.php?457794
in this thread there is a photo of what I consider a great LED and beam, my favorite LED sw45k
https://www.candlepowerforums.com/vb/showthread.php?458438
some people just want light, they dont care about what color it is, they dont care what CRI it has, they dont care if it has green tint, they just want bright, now!...
https://www.candlepowerforums.com/vb/showthread.php?452461
some people want a light with 12 levels below 2 lumens
some want to shoot coyotes
some wear slacks and work in an office
some wear a light in a hip holster
some use pocket clips
what do YOU want to use a light for?
