D
**DONOTDELETE**
Guest
This will be brief as I must go to work, but I want to get this out to you. My AT-785 ebay light arrived yesterday. See this thread. I sent it back today. Light came in a foam sleeve in an old modem box via First Class mail. It's as pretty as the picture. No identifying names or numbers on light. Beam was of course not as bright as my Inova X5 original but I was very pleased with it. Tighter than the Inova. Not bad at all imho.Wish I had the Opalec to compare. My Arc LS is in the shop...See comparison beam shot. The beam tint is not blue as in photo. Maybe a very slight hint of light brown on corona, and some blue tint in hotspot. After 2 hours the light output suddenly dropped to less than my Arc LE. After 3 to 4 hours the light remaining is basically useless, even for reading. Tested again with same results, both times using two brand new Rayovac maximum plus AA alkaline batteries. I did not test lithiums, and do not know if they can be used safely. Inside of body pic reveals apparent defect in assembly. Is that an o-ring squeezed in there? Tailcap also has about 1/32" play in it. When unscrewed (turned on) you can push down on it and cause the light to flicker. More than once I unscrewed tailcap and light did not turn on at all. Screwing it all the way closed and trying again usually worked. Other than that, light appears solidly built, nice and hefty, excellent finish. LED's (slightly smaller than the Inova's) seem mounted well in head, which cannot be twisted off by hand. Has a nearly identical spring loaded center pin in head like Inova. Batteries go in tail negative end first. It's a shame. This light could have been a contender. YMMV. Based upon my experience, I cannot recommend this light.
Jim
P.S. Other members please share your experiences with this light...
Jim
