[ QUOTE ]
vhyper007 said:
...Am having difficulty with the switch on the fb2 with the KL1.
To operate correctly the tail has to be unscrewed almost to the point of falling off the light. Does anyone have any ideas to solve this?
[/ QUOTE ]
Let's see if I can help you with your second problem with the FB2 switch. I'll just do a quick cut and paste from another thread I posted on and let you read how I fixed the problem with two of my FB lights.
[ QUOTE ]
TrueBlue said:
OK, I know this is an old thread and everyone has perfectly working VG switches in their lights but if you wanted to know how I got rid of the battery pushing the switch contact and preventing the light from turning on then read on.
I've fixed two flickering VG switches by taking the tail cap apart and sandwiching aluminum foil to the inside ring of the switch between the switch and the rubber switch cover. It is a 10 minute fix and the VG switches now work reliably.
When the tail cap is tightened down the battery pushes the switch board away from the negative connection around the rim of the retaining ring. In my simple mod as the VG tail cap is tightened against the battery, the aluminum foil sandwich acts as a backup connection grounding to the wall of the VG tail cap. Luckily there a big negative electrical connection on both sides of the switch board so adding aluminum foil to the back side of the board will still maintain a negative connection.
Make sure the foil is tightly pushed against the switch board or it may short on the little holes on the sides of the switch.
No compression rings were thrown away and no O-rings were added. The light works and looks like the original light. But the switch works better than the original switch.
The fix is easier done than said.
[/ QUOTE ]
