VanIsleDSM
Went to the metal store yesterday and picked up some aluminum for my flashlight I plan I make from scratch. I've already built a custom buck driver that will utilize 12 18650s in series to drive 9 CREE R2s in series with adjustable output.
There will be 4 rows of 3 18650s as shown in the pic.. I just bored out a little piece to fit them in (only have 2 18650s right now so I used a co2 cartridge as a dummy for fitment, same diameter, others are on order)
Wall will be about 5mm thick on the body.. after I knurl and design and such I imagine it may be down to 4mm in some areas... still nice and heavy duty.
I've haven't done any threading on my lathe yet.. have to grind myself a couple tools for inside and outside threading and start practicing a bit... also gotta do some of reading first to make sure I've got the basics figured. I read a trick to making the threading easier.. to just stop the lathe at the end of the thread, reverse it back, and then take another cut.. and this way you need not worry about the thread dial. I think I'll probably go that route.
As I'm only working with a 7x14 I'll think I'll just barely be able to bore it all the way out. reaching from both sides and repositioning the boring bar further and further out of the holder as I go. I think to make things easy working on the body.. I'll just do the threads on the outside of both ends.. then the head and tail cap can have the inside threads. This way if I can't quite reach from both ends with the boring bar through the body I can cut it shorter and just make a longer head and longer tail cap just bored out the same ID as the body to accept the same length of batteries.
I'm definitely a novice with the lathe.. so expect some questions pretty soon! ..a few things to do first though.. need to order up a live center and a steady rest. So far I've really only been doing things close to the chuck.'
