Marduke,
I have a old PS1 Rayovac charger and was wondering if it had smart technology. Did you ever find what you were looking for in the post below?
Marduke
08-10-2007, 04:32 AM
Sorry to dig up such an old thread, but I am looking to blow the dust off my old Rayovac PS1 charger. Several years ago, I was using this charger with Duracell 2000mAh NiMH, but was annoyed with the rather high self discharge rate, and my digital camera at the time did not like the 1.2 volt output of the cells. My model is one of the later generations which is capable of charging alkaline, Ni-Cad, and NiMH, and looks identical to the one pictured below. It's output is 2V, 200mA x4 (each channel).
I would like to know several things from anyone with knowledge about this charger.
First off, I believe it to be a true smart charger and not simply timed. I think this because you can load anywhere from 1-4 cells, and only each side has to be paired for the same size and type. Also, while charging, each cell's indicator light will go off at a different time, an indication of it sensing when peak capacity has been reached? Supposedly, it even senses which type of cell is inserted (alkaline, Ni-Cad, NiMH). Can someone confirm that is is indeed peak sensing and not just timed?
Second, would this charger be acceptable to use with the new hybrid LSD cells? Most of the cell manufacturers advertise that their cells work in just about any charger, but I don't want to damage them.
Third, this charger was originally advertised that cells can be left on after the charge cycle is completed, and a trickle charge will keep them toped off. Would that be fine for cells like Eneloop, or other hybrids?
Also, I know that this charger is relatively slow, but I don't mind leaving cells on overnight, or even for an entire day. So that is a non-issue for me. Also, would there be any trouble in using newer 2600+ mAh cells with it?
http://www.prosportwatches.com/client/Images/200/rayPS1.jpg
Marduke
