outerspacehoppp
- Joined
- Jan 5, 2008
- Messages
- 7
Can anyone recommend a supplier for Rechargeable CR123 batteries and charger for my new PT Apex Pro?
I am slightly worried that if I just buy some from ebay\ledshoppe they may not fit in the Apex battery holder since the regular cells supplied with the lamp are quite a tight fit.
Also which rechargeables do I want, 3V or 3.7V? which voltage will work best with the lamp? is there any capacity difference between the two voltages? will the 3.7V run the lamp in regulation mode for longer? will the Apex work OK at the higher voltage of the 3.7's? which voltage will run the lamp for longer?
I really want a charger that will plug into the car as well as mains electric.
I've just received the Apex Pro lamp and so far I am pretty pleased with it, tis a great improvement on my Petzl myo 3, which had become unreliable due to a crack in the wire at the lamp end.
Any advice about the RCR123 cell and charer suppliers greatfully received.
I'm in the UK if that makes any difference.
Thanks in advance
Outerspacehoppa.
Thanks in advance
Outerspacehoppa.
