Help Support Candle Power Flashlight Forum
I'll take one of those bad boys in my SFIII, please!
), each die of the SMT is rated at 1000mA maximum. I'm not sure how many lumens it will put out at that current.I've been trying to decipher the data sheet and here is what I've come up with...
As you can see, this led produces a bit less light (and is a bit less efficient) compared to the multichip LEDS by Seoul and Cree, but comes in a much smaller die package. This makes it much better suited for reflectors (and longer throw). I'm guessing the "doughnut" beam will be less of a problem with this LED. I personally would gladly trade a few lumens for a better throwing beam. This certainly looks like another excellent multichip LED.
Well let's not get too carried away. He said "I will be receiving Ostar SMT's from a PZ brightness bin which is minimum 610 lumins to 700 lumens." Given this figure, the Seoul and Cree still beat it in total output.
I'm not sure what bin they used for the efficiency figures, so those values may catch up to the Seoul and Cree.
Perhaps he meant that the light gives 30% more throw than the MC-E? I don't see how it could give 30% more total output at the same drive levels.
toby_pra: Will post the standard grip soon.
Can you guess what LED this is? Its 30% brighter than a MCE M in brightness.
ARC mania
This SMT led is similar to the Cree MC-E (and seoul P7). 4 dies that you can individually access (like the MC-E). The Seoul P7 is hardwired all 4 dies in parallel.
For this LED (and the MC-E) you willl get the same output with 3.6V, 2800mA (wired parallel) and 14.4V, 700mA (wired in series)
At 3.6V and 2800mA, this LED will produce 710 lumens
For comparison, Seoul P7 DSWOI specs are 3.25-3.5V, 2800mA 800-900 lumens. Cree MC-E M bin has similar specs of the Seoul P7.
Efficiency at 350mA per die:
65 lm/W for the SMT
89.28 lm/W for the Seoul P7
89.28 lm/W for the Cree MC-E
Efficiency at 700mA per die:
50 lm/W for the SMT
81.63 lm/W for the Seoul P7
84.03 lm/W for the Cree MC-E
Efficiencies for the SMT were taken from the datasheet, P7/MC-E efficiencies calculated by TexLite
Whereas 700mA is the maximum current suggested for the Cree MC-E and Seoul P7 per die (a guideline not followed here at CPF), each die of the SMT is rated at 1000mA maximum. I'm not sure how many lumens it will put out at that current.
I think that is about all you can get out of the datasheet. It would be interesting to find out what tints are available.
Great work on finding this gem, ARC mania :thumbsup:
...... To find the truth, I physically tested and came up with the result. The Ostar SMT in a PZ bin in brightness has 30% overall brightness than a M bin in brightness MCE. .....
ARC mania
Its great that you tested these professionally and are considering different options of led in the SF-III. :thumbsup:
However, please could I ask how many Ostar SMT PZ leds you tested?
Wouldn't you have to test a large sample size to safely come to this conclusion? ie. that the Ostar SMT PZ is always 30% brighter than the MC-E M-bin.
After all you said that M-bin MC-Es can vary quite a lot in brightness.
Maybe the Ostar SMTs do as well?
PS! I mean no disrespect by asking this. 🙂
Buy one and find out what I am talking about. My lights also have a great resaleability 🙂
ARC mania
and the money to pre-pay for the SF III! :twothumbs
