MacTech
I have a spare E series head/bezel that i'd like to try my hand at modding
the only tools that i have available to me are drills, and a Black and Decker Dremel-clone, i have no access to a lathe or other sophisticated machining equipment, and even more importantly, no skill to speak of
my plan is basically to find a way to cut off/drill out the "neck" of an E series head (older non-crenalated bezel) to allow me to insert the light engine "pill" of my old G&P 3W Luxeon upgrade (P60 style)
the potential flaws in this plan that i can see are;
the reflector of an E-series head appears to be part of the actual head itself, there does not appear to be a seperate removable reflector, so simply drilling out the neck (even if done slowly) is risky, there is potential to damage the aluminized reflector, however, given the cramped quarters inside the head, it also appears that cutting the neck off would be problematic without specialized tools
so, given my tool arsenal of a drill and a "Dremel", what are my options in re-machining the head, or do i even have any
Hmm, as i've been thinking about this, i may have come upon a solution....
i believe there are Dremel bits that are essentially a half-sphere of grinding material with the mandrel shaft sticking out of them (think of a round lolipop with the bottom half cut off)
if i keep the cutting RPM's low and use a cutting fluid (water? 91% Isopropyl alcohol?) i should be able to minimize damage to the reflector, and slowly grind down the neck.....
