I have a mag 4C that I am trying to figure out what to do with, and I came across this post:
http://www.candlepowerforums.com/vb/showthread.php?t=72194
This is the part that concerns me:
A. Mag18C
Body: Mag 4C
Bulb: Welch Allyn WA01318 (or WA01331) 9.6V, 1.93A, 534 spec bulb-lumens
Lens: UCL (Borofloat for extreme use)
Reflector: Fivemega OP Cammed drop-in, modified Carley RF1940 or Otokoyama PMR (out of production)
Batteries: 4.5 x CR123 (4 x CR123 + 1 x AA lithium)
Battery holder: PVC tube with tape ring spacers, foam or rubber hose
Supplemental: For PR-base potted WA01318, none needed. To use bare bi-pin bulb, install the MC BP mod.
Notes: This is an overdrive mod and suitable for backup storage use. It makes over 900 bulb lumens and nearly 600 out the front
So, they are suggesting 4 cr123 (primaries? 3 volt, what 800 mah?)
And one 1xAA lithium (again, primary? 1.2V like an energizer E2?) (900mah)
So, besides the different capacities(nominal) what about the different voltages as well? Unless they are talking about a 14500, but I doubt it as I think that voltage would be way to high.
I was under the limited understanding that when using multiple lithiums, ideally they should be protected. And if not, in the case of using primaries the voltages must be matched. Is this not ALWAYS the case?
A. Mag18C
Body: Mag 4C
