I like to have an uniform beampattern like the zebras have as it makes it easier to distinguish between obstacles on the trail then with a bright hotspot and some faint spill.
This is why I am talking about a headlamp with two options: Spot and Flood. On the camp site I typically use Flood option. For walking too, but sometimes, when I see something interesting far away, I'm easily switching to the Spot mode.
OK, if your light don't have ability to change the beam, the solution that you have main beam (Spot) surrounded by little darker external beam (spill) is OK. But IMO ability to change the beam width is far, far better
Consider the situation when you want to lighten nearest area (1-2m around) on the camp site. If you can't change the beam width, you have unwelcome, blinding spot in the center.
Diffuser gives more equable, smooth light, ideal for lightening the camp area.
Also throw on a headlamp means you have to turn your head quite precise and for anything you`d like to see.
Yes, this is why you use it only when it is needed. And remember, that the spot circle becomes more and more wide when you increase the distance. I tested a headlamp with a 5 percent spot and in fact, when you are talking about the range c.a. 100m, it could be narrower.
The benefit of the spot light is that your lamp is not lighening anything you
don't like to see :")
Thats why i am carring a zebralight for the head and a dedicated thrower for the hand if i need to look further down the trail or search for a biviplace offtrail.
The consequence is that you have to take two lamps, not one. The package becomes heavier and you don't have both hands free on the trip.
I believe you never worn a zebralight.
Yes, you are right.
The main reason why I scratched that kind of laps from the list is the power consumption. Longest running model, H60, works about 4h when you use maximum (110lm version). This is really short time!, compare it to the Myo RXP, which on the 140lm setting works 50h (12,5 times longer!)
And RXP is consuming batteries very fast, Myo XP runs 80h on the maximum setting (85lm), which makes it 20 times longer than H60, and i.e. Mammut X-zoom works 120h (30 times longer than H60)
And I don't want to change batteries every day on the camp site - it makes thing complicated and you wouldn't like doing it during a heavy rain
Also consider that the Zebra's running time is given for lithiums, and Petzl's or Mammut's - for typical alkalines.
The headstrap is only addition to calculations above.
The headstrap is really nice and as the zebras are angeld it gives you better freedom than any petzl light in terms off turning the light around.
OK, but from the other hand, the silicone holder will probably not allow to change the angle of the head as easily as in the "typical" headlamp.
Imagine that you are operating i.e. with a gloves...
Nevertheless, the main reason why I wouldn't choose Zebra or other lamps like it is that you need to change batteries very often, as well as need to have quite big amount of spare ones in the backpack when you go i.e. for a 2-week trip.
Even for a weekend camp you should take at least one spare battery.
