alternety
I have a power tool that has a 36V 2.4 AH NiCd battery pack. It takes 24 hrs to charge and runs the tool for 15 minutes. The rough size of the batteries themselves is about 6" X 2.5" X 4". It is made of 3 stacks of 9 round cells. The battery gets quite warm on both charge and discharge. They also put a thin layer of foam around the batteries. Probably to keep rattling to a minimum. But I really question the impact on heat dissipation.
I would like to build a battery pack inside the existing battery case, with at least 3 times the energy content at those discharge rates. NiMh would be easiest, but not a big capacity multiplier. It would be interesting, although not cheap, to do something with a lithium chemistry. I am not a battery expert; and would appreciate some thoughts on feasibility and possible cells/batteries. I understand that this would require a different charger. The tool's charger says it will do NiMh.
