the ray-o-vac (renewal) charger that i have was FAST, it was to fast in my opinion. it would heat up the batterys in it.
i altered it with foil to defy the thing and used it to charge other batterys , and it was fast and mean on them also. the whole technology was not at all for me, if you totally discharged the battery, it was garbage.
so when you ask about using the renewal charger on some other (rechargable) alkaline, i gotta wonder if the charge rate itself, didnt add to the short life of the entire technology for ray-o-vac. AND for me.
for me that was one expencive set of junk. i wanted to use it where self discharge would not be an issue, stuff that you dont change alkies for long times, and only after the battery is totally dead. i might have got 5 cycles on average out of the whole set.
it would be good for the constant topping off of a lesser used battery.
