https://www.candlepowerforums.com/v...-Rechargeable-battery-options-for-Surefire-6P
http://candlepowerforums.com/vb/showthread.php?166384-rechargeable-123s-instaflashed-P60!!-HELP!
https://www.candlepowerforums.com/vb/showthread.php?213507-Surefire-6p-Rechargeable-Option
https://www.candlepowerforums.com/vb/showthread.php?118306-Rechargeable-123A-for-the-Surefire-6P
Many CPFers ask me similar questions: How to use P60 genuine incandescent with rechargeable battery option and what is designed voltage and how to get there.
According to THIS and THIS you will see that each battery voltage drops to about 2.5 volts for P60 and about 2.2 volts for P61. So:
P60 is 5 volts with current draw of about 1.2 Amps.
P61 is 4.4 volts with current draw of about 2.4 Amps.
As you see, nominal voltage of primary CR123A is 3 volt and that's why they call 6 volt bulbs while they may sevierly overdrive (P60) at 6 volts or even instaflash P61
So what is closest battery voltage to bulb design voltage?
Some people suggest single 16650 (or 18650) at 3.7 volt with yellowish underdriven system.
I suggested 4AA round bundle Eneloops which is too bulky. 4AA inline will be too long and out of question.
Three of 1.5 volt AA regulated output voltage batteries at 4.5 volts is closest for P60 and very slight overdrive for P61 (If capable of 2.4 Amps.)
Advantage is healthy powered regulated and same output from begining to end of battery charge.
Possiblity of 3AA size is 1D, 3AA ,, 3AA D26, 9P with 51mm ExCap or 80mm extension tube on 6P.
