rechargeables in Streamlight Lux Jr
ob1
Streamlight does not recommend using rechargeables but I know many of you on here do. My question is is it safe to use 2500 MAH nimh batteries in the Streamlight Lux jr or no?
Yukon_Jack
Alaska
The 2500 energizers is the only thing I use in my Streamlight Jr.s. The lights seem to run just a brightly, the runtime seems good, will they shorten the life of the LED - I have no idea and may never know.
PhotonAddict
Mtl, Canada
I use Energizer NiMHs 2300mAh in mine. It's usually on for approx. 15-20mins at a time so it gets slighty warm but that's about it. Current draw from the batteries is a little higher for the NiMHs as compared to a fresh set of alkalines but I presume that is the regulation circuit compensating for the slightly lower voltage of the NiMHs.
