Recommend me a drop in module, special purpose, see inside
Marty_DK
Hi guys
I’m new on the forum (although I’ve known of its existence for a long time).
In the past, I’ve been occasionally lurking and appreciating particularly the custom jobs shown in here :)
With this in mind, I decided to ask you guys for advice when looking for a drop in module for a bit of a special project.
I’m developing a new airsoft platform, loosely based on the M4, called the M4F.
Part of the platform is an integrated, tactical flash light where I’ve previously used a Cree compatible drop-in module with a 22.5 mm diameter purchased from dx.com.
However, I’d like to find a narrower drop-in module with the same or better characteristics, if such a thing even exists – This is where you come into the picture with your vastly superior knowledge.
So what are the characteristics I’m looking for?
  • Low cost
  • White light (as in, not blue, red, yellow, etc.), I know “white” is a very loose definition if you want to be scientific.
  • Narrower than 20mm if possible.
  • Can accept either 5V or 11.1V (LiPo, which means around 12.7V when peak charged)
  • Single mode only. I’ll be controlling the LED with a uCPU, so I’ll generate special modes myself. It just needs to turn on with full power when powered.
  • Ideally, it should have a very narrow light cone of high intensity with a bit of spill at a wider angle.
  • I can’t really put a value on how many lumens, I want. The current module is 3W, if I recall right. Powerful enough to illuminate when in dark or low light areas, but useless in daylight (would be nice to have, but I suppose that’s asking too much, given the target size of the module).
I’ve copied the default recommendation checklist in below, just to make sure I didn’t skip any relevant questions and filled out as well as I could.
If you’re interested in seeing the project I’m working on, pictures and info can be found on my web page, www.cultoftheelectron.com (not selling anything, so this is not an elaborate plot to scam anyone, it’s just for the curious).
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
__X_Up to $25.
____Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
____I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
_X__Other _drop-in module__________________________________
4) Size:
__X_MICRO - Keychain size.
__X_TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don’t know/I don't care.
5) Emitter/Light source:
__X_LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
_X__I am interested in assembling my own components. (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
_X__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
__X_I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
__X_I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
__X_I want to illuminate my entire backyard or a campsite (150-300 lumens).
__X_I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
__X_SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__X_Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
__X_Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
__X_Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
__X_Less than 1 yard/meter (reading, other close work)
__X_Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__X_5-20 yards/meters (check out a noise in the backyard)
__X_30-50 yards/meters (I have a big backyard)
____150+ yards (I am searching from a helicopter)
_X__Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
_X__Not Important (A “night-stand” light).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don’t know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don’t know.
__X_Other, please specify__I make my own switch___________.
_X__A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
_X__I don’t care.
____I don’t know.
15) Water resistance
__X_None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
_X__In house (temperature/climate controlled environment)
_X__Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
