Recommend me a flashlight for: Nighttime Macro Photography of Bugs
JordanMFT
Hello flashlight experts!
Im looking for a flashlight to use for macro photography at night. The one I'm using now is the harbor freight 9-LED light (SKU 69111). Its about the right size, but its very unreliable and the light color is very blue.
It needs to be short, thin, and light enough that I can easily hold it between my middle and and index finger, and bright enough that I can see the subject through the viewfinder at night. I don't want one attached the the camera because I want to be able to search for bugs without waving my camera around, and I already have a flash mounted on the hot shoe.
Here is a picture of how I hold my camera and flashlight:
Any ideas would be really appreciated!
-Jordan
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
_X__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! 🙂
____Less than $25.
____Less than $50.
_X__Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
_X__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
_X__Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
_X__LED (known for efficiency, longevity, and compactness)
_X__Incandescent (known for superior color rendition)
____I don't know.
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
_X__I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use? Either Li-ion or alkaline off the shelf (i get them free from work)
_X__I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
_X__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
_X__I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
_X__I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
_X__Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
_X__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
_X__Slightly Important (Walks around the neighborhood).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
_X__I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
____I don’t know.
_X__A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating I would like something light, but not flimsy
_X__Plastic/composite body (this may limit your choices significantly).
_X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
_X__I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
_X__Warm or neutral color temp
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Is the light for you or the camera? That is, will the flash fire and wash out what ever the flashlight is doing ?
I ask because, the off angle lighting from a handheld source can dramatically improve/replace the 'flat' look produced by camera mounted flashes.
If I understand correctly, you use the flashlight so you can visually find the bug, and then see it through the view finder to compose the shot....but your flash is your primary lighting for the picture itself?
I use a flashlight in an analogous fashion, as in the dark, I can't see the subject in the viewfinder to compose a shot...so I use the flashlight to give me a way to illuminate and acquire the target.
Interestingly, your grip on the light might work with a side switch - so you don't have to reposition to change brightness, turn it on/off, etc.
A Zebralight SC600 or SC600W would work. The 600W = warm....more amber than than white. The 600 (no w) is a white light...but not blue.
For CRI, I actually think that the SC600 is a good choice, especially as your flash is used to illuminate the shot as well anyway...so you'd have 2 light sources for better depth, etc.
You can set the SC600 for over 11 brightnesses, or just use the 3 default brightnesses (That's all I do...). It does have memory, so it will come on at whatever you had it on last...which would probably work for you.
In your pic, it looks like your left pointer finger would fall naturally on the side switch...which would be very convenient.
The beam is floody, so you don't get that washed out central hot spot that some lights produce...making searches of large surface areas very efficient. (You can see more of what's out there at a time)
I also use a UV light, as some of the critters fluoresce in UV light (Scorpions, etc).
It uses a single 18650, which would have enough run time in that application to run a LONG time.
On Turbo, it pumps out 750 lumens of floody light....but you can throttle that all the way down to less than a lumen if you wanted to. I'm guessing ~ the medium default output would be about right for most of what you are looking at...but it can be set to what you want either way.
Fenix LD10,LD12, LD20,LD22.. what'ever
the key here, I think, is the diffuser tip that fits any of those lights; it's like carrying a lightbulb
and whenever I find something funky at I wanna take a picture of, a hotspot makes getting a decent pic a nightmare for my camera.
...then again your camera is way better.
My flash will do all the work for exposing the subject - the shutter speeds I'm at are really fast and the aperture really small. TEEJ is correct: the light is to illuminate the target so I can focus on it... when the subject is too dim the viewfinder is slow hard to use.
The SC600W look really good - and I'm sold on the idea of the side switch.
I really like the fact that its uses rechargeable batteries too.
Thanks everyone!
Now on to eBay to see if there is a used one...
-Jordan
Having an off-camera light source produces a more pleasant result.
Long exposure with a moving flashlight(s) gives you another look.
For me with a 50mm f/1.4, having 2 L2P lights is more than enough for a 1-second exposure tripod shot of flowers, and sometimes I have to step down the aperture a bit (f/2 with iso 50) to avoid overexposure. In my experience, a $1-store LED light would have been sufficient for my case. From the look of your setup, it seems you're using a f/5.6 lens at the 85mm zoom range + macro adapter, so you might need a stronger light.
Lighting up a path with trees is another matter and having 4 18650 lights ziptied together helps me.
In addition, if you shoot in Raw format, blueish color rendition of your flashlight is irrelevant, since you can adjust color temperature with minimum damage to image quality. If you're using the light for your eyes only, having a orange tint is much better than a blue one when directing it at green foliage, and thus improving your shooting experience.
To conclude, I recommend a high lumen out-put 18650 light with H/M/L modes so you can vary your looks when used as a light source.
I know you're not keen on a camera mounted light, but I use a 'spotter' gripped with a Joby Mini tripod - the tripod has a quick release top-plate for removal from the camera but in years of taking macro shots I've never taken it 'off camera'
Well there's a fantastic use for those articulating tripods I hadn't thought of yet. Always thought the joby's looked like they'd be handy, now I really want one.
It's not clear from the top pic but the light's angled up around 45 degrees - it lights the subject from underneath so as not to interfere with the photograph too much
The flashlight itself if a freebie Christmas promo, so nothing special, but it does it's job just right
It's fitted with a lanyard on the rear cap which I knot around the tripod as a safety cord just in case the legs 'relax'
Does the camera have manual white balance? I shine my off-white tinted lights on a cream coloured wall, and choose a spot that's slightly away from center (the whitest part of the beam) to adjust white balance and the colour comes out a little warm which is exactly what I want.
