Recommend me a light for...a prototype project.
RalosEkoms
New member
Hi CPF! I'd love your help getting some recommendations for a prototype project I'm working on. At this stage I am gathering information about what types of components I would/could need or use to make the vision come to life (and how much it might cost). The design I imagined is essentially a high-output light in a regular handheld flashlight housing which is meant to be used in the home whilst plugged into a power cord that goes into a wall outlet. It's primary use will be at a very close range (possibly at contact with the end of the light touching or just inches away from the target) for short periods of time (30-60 seconds at a time, but must be able to do so repeatedly) to heat and vaporize organic molecules.
The specs below may seem more like a lamp than a flashlight but bear with me, your suggestions and recommendations will be much appreciated!
Some questions I have are:
What kind of bulb and reflector do I need which will: last a long time, generate a lot of heat/light at a range of 0-3 inches?
What kind of internals do I need to accommodate a strong emitter powered by a wall outlet?
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
_X___This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
__X__I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
____I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
__X__Other I'm imagining a handheld style flashlight which plugs into the wall
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
__X__I don’t know/I don't care.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
__X__HID (known for max output, but often at the expense of size)
__X__I don't know I'm looking for whatever generates the most heat. I'm guessing HID but not sure...what are your suggestions?
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
__X__I would like a light from a specialty manufacturer (Possibly limited run/Custom).
__X__I am interested in assembling my own components. (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
__X__I don't know/I need more information on power sources. Needs to be able to run while plugged into a wall outlet
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
__X__I want search and rescue type illumination (800+ lumens).Not sure about this one. I'm looking for something that can generate a lot of heat at a close range.
__X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
__X?__Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
__X__ Contact - this light will be primarily used for heating things
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
__X__ Plugs Into The Wall - battery longevity not necessarily a concern.
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
__X__I don’t know.
__X__Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
__X__I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don’t know.
____Other, please specify.
__X__A simple on-off with only one output level is fine for me.
__X__I want multiple light levels. (Some lights have 5-16 light levels.)Could be simple on/off but would be useful to have a twisting knob which adjusts brightness/output
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
__X__I don’t care.
____I don’t know.
15) Water resistance
__X__None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
__X__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
archimedes
Moderator,
Staff member
CONUS, top left
If your primary purpose of this device is to be heating and not illumination (and yes, noting a distinction between IR illumination and specifically heating) ... then you are not really describing a "flashlight"
If you care to provide more specific details of the purpose, this thread could then be moved to a more appropriate forum.
Hoka Hey
Active member
Sounds like you want a heat lamp. Available at farm store for chicks, or pet store for lizards and snakes.
