Recommendation for first 18650?
Qooo
Hello everyone. I've used CR123's most my life but from lurking candlepowerforums, it seems that 18650's are pretty popular. So now, naturally, I'm interested in getting acquainted with 18650 lights but I'm a total newbie when it comes to these types of batteries. What "entry level", good-out-of-the-box would be good for getting "acquainted" (addicted)?
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__x_This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
__x_Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__x_I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
__x_TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__x_LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__x_I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
__x_I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
__x_I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
__x_I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
__x_SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
__x_Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
__x_50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
__x_90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__x_Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
__x_I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
__x_I want multiple light levels. (Some lights have 5-16 light levels.)
__x_I want a programmable light.
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
__x_Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
__x_IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
I would recommend you take a look at the Eagletac D25LC2 with the XP-G2 LED since you want a nice hot spot. It's one of the smallest single 18650 lights out that still uses a clicky switch and will be easier to carry daily. It ticks off all your checked boxes except that it is not programmable, but it does have many modes.
Thank you! Requirements are not set in stone as far as mode settings so it wouldn't bother me too much whether it is programmable or not. What about the batteries or charger? What's your experience with good/bad ones? Thanks again.
I've never had a bad battery yet, mostly because I buy well reviewed batteries from legitimate sources. I strongly recommend doing some reading down in the battery section of the forum, and checking out fellow CPF member HKJ's website here.
I've personally used AW, Zebralight, Eagletac, Nitecore, Cytac and many more cells. Most of these are just rebranded Panasonic cells, typically the NCR18650B now days. I've used many chargers as well, but have recently acquired the Efest LUC V4 charger and like it quite a bit.
4) Size:
I suggest to reconsider that, and/or reconsider some of the other wishes you indicated. You can't freely pick sizes as desired, flashlights are built around batteries and there's other essential stuff that makes a light.
I've got an 18650 light that measures 97 mm. (3.8") in length, and that's already quite small for an 18650 light: shallow reflector, perhaps 1 cm. for the driver, low-profile tail clicky, very short contact springs, and protected 18650's don't fit.
You're looking for a thrower, and throw requires a deeper reflector than a mostly floody light.
Also tail clicky switches tend to add length. And for a beginner, I'd recommend to start with protected 18650's, which adds another 3-5 mm. in length.
So I suggest accepting somewhat longer lights, otherwise you'd severely limit your options. Which much nicer choices just a length-cm. or two away. :D
Many folks on here wouldn't consider an 18650 light EDC-able in the first place. Most likely either you're looking for a compact, mostly floody light (possibly with electronic side switch). OR you're looking for a thrower which in most cases will be bigger/longer. Or get both... :devil: Try to combine that in 1 package and chances are you won't get what you were hoping for.
Sweet. Thanks for all the help guys.
Getting a lot of good reading in batteries.
@ RetroTechie very good point.
My mistake, I originally thought the 4Sevens Quark 123 came in under the 4" and figured that a good starting point. I just did a quick measurement and the light comes to just over 4.5" while the Quark Turbo is just over 5".
Fixed:
__x_SMALL - Every day carry (4-7 inches).
So I'm what recommendations do you guys have for a light in the 4-7 inch ranges?
Maybe I'll experiment with xx650's in Quarks but then I won't have an excuse to add another light to the collection. :sigh:
Armytek Predator (or -Pro). Not the smallest, but (modded/custom lights aside) probably the best thrower for its size.
Olight 1x 18650 tactical lights like some in Mxxx Warrior series.
Sunwayman, Eagletac, Nitecore, Thrunite, Fenix etc might all have some compact throwers, but be sure to check reviews / beamshots before buying! Some are advertised as throwers but aren't that throwy at all...
Personally, for an EDC, I would look for light with a Cree Q5 that uses 14500 and AA batteries. (By EDC, I am thinking pocket carry, not holster.)
My reasoning is they are inexpensive ($10 max and EDCs get lost a lot) , they have enough output for most general use (around 150 lumen with 3.6v battery) , and you won't be night blind when you turn it off.
If a pocket model, get a smooth sided one, so it doesn't chew through your pockets, or bust a phone screen.
BTW, a two D cell old fashioned light with a standard bulb is only 7-10 lumens.
You can search the usual online sites to get an idea what shapes and sizes are available.
Personally, I think a AA mini-mag shaped light with 150 lumens and adjustable zoom would be perfect for my daily EDC, carry in my pocket needs.
Please let me know if anyone finds such an animal in the wild. I have 4 old mini mags (and 15+ other such lights) that I don't use anymore, because I got spoiled by the newer, much, much brighter lights.
-My name is Luminski, and I am a flashlight-a-holic.
for a good first 18650 light, the Nitecore P12 is my recommendation. But, if you want one that's small enough to EDC, the Zebralight SC600 would be my choice for that.
Ditto to the Eagtac d25lc2 xp-g2. look for the xp-g2 r5 factory custom 2 amp mod. it will take the fat orbtronic or fat fasttech panasonic 3400 protected cell. nice tight hot spot. interface with the head tight for turbo & blinky. head loose for high & lower modes. one of the on-line retailers may still have them. i found an olight diffuser that fits but never use it. it is a lighter & slimmer than the zebra & has much tighter hot spot. both are good choices.
Wow, pictures don't do justice at illustrating just how small some of these lights are.
Not sure they fulfill all of your criteria, but Zebralight SC600 II L2 and SC62d have relegated all my other lights to shelf queen status. SC62d in particular is absurdly small for a 1x18650 light, has a great tint, excellent UI (same as all ZL's), and great range of highs and lows. Admittedly not great throwers -- but if small, powerful, EDC'able 18650 is what you're after, these are hard to beat.
OTOH if you're really looking for throw, Retrotechie's suggestions of Armytek Predator and Olight M series are great choices.
Yes, sweet light as well. What made you prefer the SC's over others?
I'm new to these new flashlights also! I've been accustomed to the Maglight and have carried one for 25+ years! Now my interest has peaked into these well diversified,and more adaptive type of modern flashlights. Fenix has their E Series models that you might take a look at!
