Red Inova X5 Best Battery Chem.?
LEDAdd1ct
Hudson Valley
I researched as much as I could on CPF and on Google, but did not feel that the information out there was quite specific enough to answer this question. So here it is, in all its glorious specificity!
I intend to buy three Inova X5 lights, all in the red LED color. There are several reasons for this, including, but not limited to, cool factor of red diodes, the fact it only utilizes one cell, and the overwhelming consensus that the little bugger is near indestrucible. Two of those lights will receive lithium primaries (one will go in my backpack, and will be given to my father as a gift), while the third will live on my dresser. Powering the dresser light with primaries is a luxury I cannot afford, and even if I could, I would rather use less "stuff." Ego boost, at the least.
This raises the topic of which chemistry to use. There seem to be two lithium type chemistries, a new type, which is purported to not catch fire/explode/eat toddlers, have an extended recharge lifecycle, and *not* have over-discharge protection (LiFePO4), and the higher-capacity, been-out-for-awhile, RCR123A type of lithium ion. I am referring specifically to the type of both chemistries that puts out approximately 3.0 volts DC, and *not* to the type that puts out 3.6/3.7 volts.
From the hours on the web and on CPF, it seems that the following pieces of information are true between the older chemistry and the newer chemistry:
-the newer chemistry holds about half the capacity of the older
-the newer chemistry is safer and ought not to explode/catch fire
-the newer chemistry, as advertised, has many more charge/discharge cycles before cell failure
-the newer chemistry, for whatever reason, seems to lack over-discharge protection
-both chemistries are immune from the "memory effect" of yore
-both chemistries maintain charge with little loss over time (compared to Ni-Cd or Ni-Mh)
-if one discharges the newer, LiFePO4 type too low, it will "refuse" to charge again
-there exist several different types of both chemistries, sold by vendors and brands such as AW, Tenergy, and Powerizer, as common examples
-the AW is reported to have more capacity at the expense of greater battery diameter
-the Tenergy is reported to have less capacity at a cell diameter very close to CR123A primaries
The above summary is a list of what I found and what I remember. I apologize if I botched some things.
So *draws a deep breath*, with the intention of running an Inova X5, with the red LEDs:
a) what is the highest capacity rechargeable cell of 3.0 volts known to *fit* in the Inova X5 tube, what brand are the, and which type of chemistry, old or "new", are they? With this cell, how much runtime have you achieved?
b) is it the case that if I use the "older" 3.0 volt chemistry, in the higher capacity with over-discharge protection, that when the over-discharge protection kicks in, the light will wink off immediately?
c) is it the case that if I use the "newer" 3.0 volt chemistry (LiFePO4), in the lower capacity WITHOUT over-discharge protection, that the light will gradually dim, exhibiting a discharge curve typical of the cell itself (i.e., a long tail effect?)
d) is there anyone out there that has wondered the exact same thing for *their* red Inova X5s, and having experimented and compared various brands, including both of the 3.0 volt chemistries, has arrived at a personal favorite brand and capacity? If so, for what reasons?
e) finally, is there a particular favorite charger used to charge these cells, that is known to be safe and terminate properly?
I greatly appreciate feedback and suggestions from anyone who has faced this problem, and immensely appreciate feedback from anyone with experience using a single cell in the red Inova X5 in particular.
LEDAdd1ct
Each Inova X5 ships with one set of primary batteries (one for red, two for white and others). This light is a true vampire when it comes to sucking every last drop of juice out of a battery. Someone here did a test with a white one, and it ran for WEEKS constantly on (20 hours advertised runtime). It was very dim most of this time, but lit nonetheless. You can find a runtime plot and other info on the X5 (white) here. Most of the info also applies to the red. As a simple nightstand light, I would be very surprised if you used up the battery it came with in under a year. With such an infrequent need for recharging, you may want to consider cheap online primaries, such as the Titanium brand offered through Amondo Tech at $1 per battery. If you own, or plan to own other lights that take CR123 type batteries, however, rechargeables start to look more attractive then. Deal Extreme w/Ultrafire batteries and chargers is a popular, but cheap way to get into the RCR123 scene. I'll leave it to someone with more battery expertise and experience to direct you to which setup would work best for you.
Edit: My gen 2 white X5 still has the original 5+ year old batteries it came with installed. I have been waiting almost 2 years to install a pair of replacement CR123's I have, but it's still just not dim enough for me to bother yet.
Also, thanks for doing a good deal of research and asking well thought out specific questions. Sometimes I wonder if some people know what a search button is.
+1 in primaries, a red X5 will run forever on a battery, it would take you 30 years to justify the price of a charger and rech. battery. Just go for a primary.
Thank you for the initial two responses. I hope there are many more to come! 🙂
Regarding usage of the light, although I specified the light as a "dresser light" above, I know from my Flashoholic habits that "intended use" and "actual use" are two entirely different animals. I rotate the lights I use on my dresser (not physically, as in switching their respective locations, but simply using different lights), and use different lights for night hikes as well. There is the possibility the light will see no more use than sitting on my dresser. There is also the possibility that being small and hard as a brick, I will take it with me wherever I go, use it frequently, and want the light to be as bright as a fresh primary on a consistent basis. For these reasons, and the concept of "guilt free lumens", I really would like to get a charger and RCR123A 3.0 volt cell, even if just one or two cells. I will concede that practicality and reality may lead in a different direction. Noted. "Over-preparedness" to the point of insanity seems to be a hallmark of certain addictions, flashlights included, and I do not spare myself from that classification. 😉
Thank you for the link to Quickbeam's site. I had already studied it to make sure I wasn't asking something that had already been asked, with specific reference to this particular unit. My goal with RCR123As is to stay in the "00:00" to "04:30" part of the curve, and avoid the "long tail" of "04:31" onward. RCR123As afford that luxury- primaries do not. This is not to say that during a long trip or blackout I would not appreciate the increased runtime at lower levels- I would- but simply that I would prefer the ability to charge in the daytime and maintain optimal output whenever possible.
Now, about them rechargeables...😱...
As you wish....
This should help you with Lithium battery sizing issues:
http://www.candlepowerforums.com/vb/showthread.php?t=174062
My gen 2 X5 internal diameter measures 0.6615in or 16.90mm. I don't think that the gen 3 or gen 4's have changed the dimmensions. With a quick search, I found these. They are unprotected, and you would want to be careful not to over discharge them. The danger of over-discharged Li-ions is primarily not from over discharging them, but trying to recharge cells that have been over-discharged :poof: . Just check the voltages before you put them on the charger.
I remember reading somewhere that at least one person was using a 3.7v in a red X5 with no ill effects, but who knows?? :shrug:
As for options, check here for the el-cheapo's. Probably won't last as long as quality batteries, but at the price, if you can use them twice, they paid for themselves.
http://www.dealextreme.com/products.dx/category.400~page.3
http://www.dealextreme.com/details.dx/sku.4419
http://www.dealextreme.com/products.dx/category.401
http://www.dealextreme.com/details.dx/sku.1191
Once again, I am no battery expert. If someone else sounds credible and has better rechargeable battery ideas, listen to them.
