jeffreyliu838
- Joined
- Dec 28, 2007
- Messages
- 34
Is there a way? I was thinking just making a small flat resistor module, and throwing that in there. Would that screw with the flat runtime? Thanks.
Sounds more like the "Win-lose" to me. The OP might be hoping to get additional runtime as well, as with the resistored McE2S switch. He might be able to double the runtime of the stock config while getting the output of the 'chapstick-cap' config, for example?:shrug:Just use the chapstick diffuser cap trick, and tape the sides of the cap to block the light. That will diffuse the light (making it appear dimmer), and reduce the total output. It will also smooth out the beam artifacts and make the tint look nicer.
That my friends is what we call the "Quadruple-Win"
I'm not really looking for more runtime (though it won't hurt). The functionality of the Eo1 as a keychain light, for me, is compromised by it's relatively high brightness. It kinda kills my eyes everytime I use it for up close work (mostly reading and stuff). I don't want to increase the size of the light either by getting a diffuser.
+1, use dead batteriesJust save your "used" AAA batteries for exclusive use in your E01. Tell your friends/relatives to save you their dead AAA's.
Here's a simpler solution.
You could swap the emitter
I have a natural and black E0, and I'm loathe to part with either. Great lights that I use often.Are there any fenix e0's floating around? I have one, but im loathe to part with it. Those were smaller and less bright than the eo1's.
I wish there was an E02 that was 2-stage, like the Nitecore EZAA. Twist on for 1-3 lumens, twist more for 10 lumens. Something like that.
