I hve an A2 and an E2E. I love the regulated output of the A2 but I love the form factor of the E2E. Is there any way to get regulated-like incan output out of the E2E? I'm wondering if a rechargeable option will give flat-like output.
If your E2e will fit a 17670 ...
Do you know if it will fit 17670's? Any way for me to figure it out without buying one?
Of course I still love my A2. I wish Surefire had made a 3 cell version!
Can you provide us as to when you bought your E2e?
mdocod said:The discharge curve of a li-ion isn't really any flatter than a CR123 at lower drain rates of the E series lamps. If the performance on CR123s isn't "flat enough" then I don't see how going to li-ion cells is going satisfy.
Hmmm ... that would be a shame. I thought li-ions didn't sag as much as CR123s under load. So, I thought the lamp output wouldn't dim as much over time.
Any why is that if I may so inquire? :thinking:
mdocod, higher voltage is what makes the incan lamps brighter. Higher voltage under load is what lithium ion batteries produce, compared to primaries. You have me all confused, because incan lamps see the load voltage on their filaments.
In general, it's been my experience than lamps are brightest on fresh primaries, brighter even than freshly charged lithium ions. But after that first twenty seconds to first minute or so, the lithium ion batteries take over in brightness for the rest of the run.
I would definitely agree with that if we were talking about E1e's MN01 levels of output... But running a higher output LA on a 17670 will give an slightly flatter discharge curve and better runtime than the same bulb off of a CR123 primaries.The discharge curve of a li-ion isn't really any flatter than a CR123 at lower drain rates of the E series lamps. If the performance on CR123s isn't "flat enough" then I don't see how going to li-ion cells is going satisfy.
I have an older E2E with a twisty tailcap, lightly crenelated bezel, and the round body with all the lettering on one side. Maybe the transition from the old square body to today's round body?
