D
**DONOTDELETE**
Guest
I have a couple of projects I was thinking of and would like to get some input.
1. I have a 3D mag-light and was considering replacing the bulb with a 3-white LED PR type bulb. my question is how will the light output be affected? I've read that the spread will be much more even but will not throwout very far. Is this configuration useable for outdoor use or only close quarters.
2. I have a 4D Fuji head lamp that I modified to run off of 6V lead-acid sealed rechargeable batteries (4AH or 7AH). The bulb is a 6V Eveready Halogen. Even with the halogen there is not much of a voltage drop on fresh a fresh battery (6.3v to 6.5v). The output is very, very hot with a spot that will highlight objects 1/2 mile away (dark night). I wanted to get a broader beam that would still throw far and longer runtime. I get around 4 hours with the 4AH. Would a LED work for this situation without too much of a reduction in output? I was also concerned about the high voltage.
Thanks for any info.
Craig
Craig
