I was on a 4-day business trip at the end of February and found myself accompanying a friend to a swap meet during some personal time.
One of the sellers had a bunch of old flashlights; mostly Maglites. At the middle of the pile was a dirty, nasty greenish-looking Minimag AA-so I thought.
I asked to see and handle it. It was a ARC LS; "First Run" is inscripted on the bezel. It piqued my interest immediately since I had no idea that ARC made a larger light than the AAA model.
I had no idea how to activate it since it did not have a switch. I twisted the head and got nothing. The seller said that it was dead. I said that I wish to test it with the batteries from my Fenix L2D-CE. No output was the result as I asked the seller how this was used.
He said that he used it to work on automobile engines. Immediately I made the connection between the hirsute gentleman's dark, greasy hands and the layer of motor oil vividly coating the entirely of an otherwise unblemished, hard-anodised AA flashlight.
I asked him what he would accept for it. He said $3.00!
I whipped out a $5.00 and did not ask for change.
If nothing else, I could use it as a kubaton.
After I thoroughly removed the oil, I placed it in a plastic bag and placed it in the bottom of my suitcase and almost forgot about it until my wife emptied it of my dirty laundry when I returned home. She said something smelled like motor oil and that it was my socks.
TSA strikes again. The plastic bag was opened but was NOT resealed.
Anyway, I just recently began modding some of my lights. All of them were easy to do so I thought I'd give this one a try. Bad news.
It took some doing with 2 strap wrenches to separate the head and bezel.
What I found was epoxy underneath the LED. I had to chisel it loose and carefully use an Exacto scraper to removed the remnants.
I used needlenose pliers to remove the ring that held the optic.
I carefully removed the excess epoxy, but am not able to remove the PCB. I need help here since an extensive search and very tentative access to CPF the last two days has not made my efforts entirely fruitful.
Thank you in advance for any help.
