Requesting schematic for NiMH charger.
SwampGas
Denver, CO
First, a general "hello" from this newby...
And my question:
Since I have more time on my hands than I want - I'm
seriously thinking about building my own NiMH charger.
My search on the web has not turned up anything "simple".
I have 2 tight specifications. One, the charger
must be able to deal with single cells. Two, negative
delta V cutoff. Other parameters are flexible - fast
charge, diagnose, conditioning, etc., are not required.
Pointers to previous posts, books, or other web sites
would be appreciated.
Thanks!
Alan
evan9162
Boise, ID
Many here have built a Maxim MAX712/713 NiMH charger. I used rotary switches to select different functions via the PGM pins. I can charge 1-12 cells, choose the time for backup termination, select from 4 current levels, and use a magnetic thermistor if I want to use temperature for charge termination.
SwampGas
Denver, CO
I looked at the Maxim web site and found a datasheet for
a DS2711. It meets my requirements for single cell
charging and -DeltaV termination. But they aren't available
at Mouser or Digikey.
Any suggestions regarding where I might find a small
handful?
Thanks!
chimo
Ottawa, Canada
Here's a Max712 charger link. It worked well for me. I made a dual charger for charging two single cells independently. I adjusted the schematic and PCB a bit to suit my needs.
Max712 charger link
