BVH
Question one:
I need help! I want to power a 4 CFM, 12 Volt fan from a 4-cell, 16.8 max Volt, 12 AH Lipo. The fan's operating Voltage range is 10.2 to 13.8V. The fan's current consumption is 170 ma/2.04 Watts. Under initial ballast load, (estimated 6-10 seconds) I'm predicting the battery to sag to maybe 15.5V but as the ballast starting cycle winds down, it may rise back to 16V within 15 seconds of initial start. Final pack voltage at depletion will be 12 Volts. The fan needs to run full-time until battery depletion. I realize rpm will fall a bit as Voltage falls but it will move enough air at 11.5 Volts.
Could one of the electronic experts point me to the proper resistor and show me the calculation that was used to bring down the Voltage range? In my crude understanding, I think I need to reduce a pack range of 16.8 V - 12.0V down to 13.8V - 11.5V. If needed, I think the final range could go down to 11.0V if it had to.
Question 2:
Is there a small electronic delay-off timer (maybe up to 1"x1"x 1/4" thick) that would sit electrically after the main light power switch and before the fan, that would allow for immediate activation of the fan upon activation of the power switch and would allow the fan to run for about 3-5 minutes after the power switch is turned off?
Question 2:
