Restoring Titanium lights
Drywolf
Golden Poppy State
Thanks to Chipwillis I have a new member in my McGizmo family. It's an XR19-PD. It was described as a beater and it has seen a lot of use. The light has no nicks and I would like to do my best to restore it. After searching the database I'm not convinced I have all the information I need to do this restoration.
If restoration is not possible then I will go down the polishing route which is throughly covered in this thread.
http://www.candlepowerforums.com/vb/showthread.php?t=160964
If anyone has a better title for this thread please serve it up. I hope if enough information is donated here it will serve as the thread many will use to get out scratches and restore their most precious Ti lights.
BTW - The piston is in sad shape as the edges have been eaten into by the screws for the clip - If anyone has a Ti piston for sale please PM me.
Thanks,
Frank
:thumbsup:
Congrats on the new light & I'll subscribe to see what comes. If it were mine I would leave it as a beater & EDC it - but that's just me. I hope we'll see some before & after photos....
There is a thread on a Ti PD or LS20 that someone took a spill on a motorcycle with and the light ended up with a nasty case of road rash. The light was restored by someone and looked great after - have you seen that thread?
Good luck! Neale
I remove scratches with the following sequence:-
P400 sandpaper, P1200 sandpaper, then 180 spongepad (fine), followed by 240 spongepad (superfine), finally followed by polishing with a metal polish like Autosol cream (for cars) with a cloth.
I found these spongepads in a DIY shop and they're actually meant for smoothing paint on walls. However they are perfect for following up after using sandpaper as they are less abrasive and lead to a very fine satin-finish prior to applying the polish. I have a feeling that scotchbrite pads are very similar and are probably more available in the US.
This process requires quite a lot of patience if the scratches are not superficial, but is very quick if they are indeed only superficial.
When using sandpaper, I roll it into a circle and then rotate it along the "grain" of the machining finish, trying to use a smooth motion.
I don't have any machines like a lathe, which is why I use the process above.
I have found it to be very successful, but it does require patience sometimes, and the cycle may sometimes need to be repeated if the scratches are deeper.
Good luck! Neale
I'm still recovering from my recent break-in so my DSLR and lights are in storage. I'll see what I can do with my point and shoot.
Here is the thread you referenced.
http://www.candlepowerforums.com/vb/showthread.php?t=172108
Nice start, easilyled
Frank
