I received the Rider RX from AceBeam for the review.
The Rider RX is a EDC flashlight, with a Nichia 219F neutral white (5000K) emitter, powered by an included 14500 USB-C rechargeable battery. The Rider RX also works with regular AA batteries. The most distincrive feature of the Rider RX is the mechanical slide mechanism that is used to take the light apart, or to play with it as a fidget.
The Rider RX is available in 2 finishes, a brushed one, and a blackened one. I got the first one.
The Rider RX comes in this carboard box, with instructions.
The Rider Rx measures 96mm in length, is 18 mm wide at the body, 26 mm with the clip.
The forward mechanical switch at the tailcap
The Light comes with a nice protective film on the glass with anti reflection coating.
Once removed the 219F emitter shows itself at the bottom of the optic lens.
The Rider RX uses the nested construction that we saw from other AceBeam models, a stainless steel brushed outer cylinder, with a blue anodized aluminum one inside. The clip is made out of stainless steel and can be used tip up or down.
The inner cylinder can be rotated and pushed outward, using the mechanical mechanism activated by acting on the clip.
First, the clip can be rotated slightly to the right,
And then pushed down, making the head of the flashlight protrude from the body.
During the travel of the clip from left to right and viceversa, the part of the clip that rests on the body travels on a milled portion, without making any extra marks.
Now the head can be untwisted from the body, showing the included 14500 USB-C rechargeable battery from Acebeam. Note that the inside of the head is made out of copper for increasing heatsinking.
The UI is pretty simple. The light has 4 modes: ultralow, low, medium, high. The light has memory mode and you need to use the forward mechanical switch to advance through the modes, in loop. After 2 cycles, you will have an hidden SOS mode.
The included 14500 Battery is rechargeable both via a standard 14500 battery charger, or with the USB-C port on its end. I tested it both for charge with a SKYRC MC3000 charger and then discharged with the same charger.
