Z
zieloczek100
- Joined
- Nov 13, 2016
- Messages
- 68
Hello,
My name is Eryk. I am writing reviews in Polish.
Reviews I translate – google translator.
Another flashlight, another Fenix, this time the PD36R model.
I have been using Fenix PD36R for 3 weeks, it's time to write a few words about it
We receive the flashlight in the classic Fenix packaging, the most important information - including the amount of lumens and the way of power supply, the latter will be crucial for this model.
In the middle quite classically:
- a flashlight
- USB type C cable,
- user manual, warranty card
- wrist leash
- spare O-ring,
- 21700 cell with 5000mAh capacity
- flashlight cover
PD36R is a classic of the genre, the flashlight looks very standard visually, only to some extent has an interesting color of the button - answering questions, I do not know what it is made of
The manufacturer has equipped the flashlight with a smooth reflector and LUMINUS SST-40 diode with a cold color. How it shines - the pictures later in the text
In the middle of the button there is a diode, after turning on the flashlight it informs us about the battery charge level - a good solution, it's a pity that it's not like in EAGTAC flashlights, where after each change of mode the flashlight informs about the current battery charge status (another thing that works with very inaccurate)
On the other side of the USB port in standard C. Rubber band protecting the USB port sits quite tightly, I have not found anywhere information whether the port is water resistant without rubber protection
The flashlight has two buttons - to change modes and a button to turn on / off the flashlight. The controller is equipped with the memory of the last mode and in addition we can lightly press the back button, which allows you to turn on the flashlight (as long as you hold the button) for as long as we need exactly
Thread properly lubricated and well made
Comparison of 21700 cell size to the standard Sanyo 18650 cell
Controller:
The simplicity of control has been limited to the absolute minimum:
- turn on the flashlight with the back button
- side button with single clicks to change modes (30-1600lm), it's a pity that we don't have a lower mode than 30lm - on my part I will say that the lack of a lower mode is in my opinion the biggest drawback of this flashlight
- holding the button down for more than 0.5 seconds activates Strobe.
The control is almost alive copied from the Acebeam EC35 - only there the lowest mode is 0.3lm
An important addition is the aforementioned LED located in the button for changing modes, it informs us about the battery charge status on a four-point scale:
- permanent green - 100-85% charge
- flashing green - 85-50% charged
- solid red 50-25% charge
- flashing red - below 25% charge
In the attached photo you can see that the manufacturer gives the estimated flashlight operation time in each mode until the brightness decreases. According to my test, this threshold was reached a little later (I tested only for the brightest mode) - this may be due to the cooling method - I used water. You want to continue using the highest mode (in terms of brightness) - you need to turn off and turn on the flashlight.
Size comparison to Securitying 700 and EAGTAC DX3G Mini Pro
The weight of the flashlight from Fenix and EAGTAC (both with the link inside), despite knowing the larger size and other power supply is quite light and pleasant to use with the flashlight
Field shots, camera settings ISO-200, f / 2, 1s, white balance - Fluorescent H
Fenix PD36R - modes from lowest to highest
Securitying 700
EAGTAC PX30LC2-R
A few words of summary:
In this part of the text I could invite you to read my descriptions of other Fenix flashlights, reason? This is another well-made flashlight with a very basic UI, I miss again, e.g. the very low level of the lowest mode, or the possibility of temporarily turning on TURBO. I also miss the option of choosing a flashlight with a warmer LED.
You can criticize, write a lot, but the truth is that control, appearance, etc. - this is the individual choice of each of us, I have been using Fenix HL60R continuously for several years, or very basic control bothers me - sometimes yes, mainly if I want to get to the lowest mode, I have to click through all available, but it's the simplest form of the driver and the people I meet often don't want to go into anything more difficult - and I'm not surprised at all. For some flashlights, apart from rechargeable batteries, we need to take the instruction manual - it's a bit like with medicines "before using, contact ..."
Thank you for your attention
Eryk
- a flashlight
- USB type C cable,
- wrist leash
- spare O-ring,
- flashlight cover
Controller:
Securitying 700
EAGTAC PX30LC2-R
Eryk
