Review: Fenix TK72R: rechargeable, 3 x XHP70, 9000 lumens, beamshots / compare
kj75
Well-known member
The Netherlands
In the past year, a new big Fenix flashlight was shown on several trade shows. The wait was rather long, but from now the TK72R is available. Fitted with three XHP70 leds, a removable accu and a charging and discharging function. Therefore a two-in-one: A flashlight that has good runtimes and a powerbank to charge your other devices. Specialties of this light are the built-in OLED-screen and the unique interface. It unique how the brightness of this light can be adjusted to your wishes. So again a Fenix that has a bunch of interesting features, which make this light very interesting to me to have a closer look at. Special thanks to Fenixlight and Knivesandtools.nl for the opportunity to test the new output-king of Fenix! In this review I’ll show you the light and its details, tell you how it works, and compare it to some other handheld-searchlights. At the end of the story a very important chapter: The indoor and outdoor-beamshots. Enjoy reading and watching!
the new king made by Fenixlight: TK72R
y82R__wlja8OVQOIY2UAdAMFFtqFc7g29xT2rl6MSVzjIRVF9IX5EjLItx4mXk1nDbPO6Nj5poVSMIY9EdVikKa9C9iGqO2ETtRWKvXpC977_WlETxSRxM_R6eFlj1A2oYGVGdKp
powerful appearance
X2c2KBWzjbKxTdpyutdD27rJCksPWenUlTOGBqc-zBY1v7gIO1vwDpQy60JB2zlZRDu0jeT83D2cnk6R-5SyLbp3ir_6r0u_qOx14bx_PaLaZjX4VxzvJPfGaSUQFr7frqKHJdCc
robust and stable
sd4v_OVJ0aiWCowiNTgV9f7pFsirYGrRi8cXdTHA7k8Q2rLRQdyQUw9nj03HEw-clYMWfGkd8gfDcPYRPEk0Qnj6jJ-VPg2bCiVubcXbWwGdy4Sof6FmCc3HnSfWpCvgNpYyGSXD
fitted with three XHP70 leds
41pLp8njMqvy0uSa9FOTrtdo3Jup8UeC1dyANqeWvhQh0L0XfL5u0CpJxJ1ruwXgWSjKZli2ZwWxZEG0O3-eq88c8L2VRrC89o-7BVcXp__pfrat5KFzvL1zfmcavt2IKroVFSMF
a control panel with OLED-screen
ays-0ikL5oWiH5Ff9mApWzW9mPg2SB2Pvyo4bjOClzEn7ANplfNLZLs1JH80Ktdp2SfYRr9XxOJp7aC9mlkKiPsSwrhnxm9-Q6nkmlGF-3OmmHP76L0fv22z8jpcgi6mLBVpf0cY
charging and discharging option
0JHoWvgoG_RxJSor0CgjvufL5VkafauF4EKfHGdj9uMJB9u9YZXQ1TL3vyh3QdERDjO64Elaiqa_91kCvVGdLya6zxrz1UPWF38UOdkfCUz8WwtCNmcXWAeAR5WGnJEUby5_-01j
Firstly, we’ll have a look at the specifications, given by manufacturer:
· Uses 3 Cree XHP70 LED's with lifespan of 50,000 hours - max 9000 lumens
· Included 7.2V/7000mAh Li-ion battery pack
· 156mm Length x 59mm Head diameter x 50mm Body diameter
· 412 grams (excluding battery)
· OLED digital screen displays: output, runtime, battery status
· Micro USB charging, USB discharging
· Inner waterproofing treatment of USB&Micro USB port
· Three switches in the neck - easy and fast operation
· Three output modes: Low, High and Memory
· Instant Turbo
· Lockout function
· Low-voltage warning function
· Digitally regulated output maintains constant brightness
· Intelligent overheat protection protects from high surface temperature
· Reverse polarity protection to protect from improper battery insertion
· Made of durable high-strength and oxidation-resistance aluminum
· Premium type HAIII hard-anodized anti-abrasive finish
· Toughened ultra-clear glass lens with an anti-reflective coating
and the output and runtime specs:
KkzLzUUo-n3fDjAL5hre8hAcaHmcogcjUtDc55wboxVjFueJAkyjCOCOPBJ0dYsQMJfNvWnq5z2SXMvqis4GOYVo_oWfv88w9t95vJdCWYFeajgHb5D1q-Si4TuPmC5G_Jawxn3j
Unboxing:
The TK72R comes in a neat “closed top” package. No plastic case here, like the TK75-2018 has, but a neat box. In front we see the light and the main applications, on the back the features and the runtime and output graphs. Fenix is proud of the RedDot that the TK72R has won, we see the symbol several times back on the carton. In the box we see some cutouts for the light and the parts; this makes it easy to (re)store the flashlight. This package is an “all-in-one” box; also a powerful charger and the battery is included. So, we don’t need anything else here; this package is ok to me. Please have a look at a couple of photos below that show the carton and the contents!
a “closed-top” keeps the TK72R in place
eNIXxYUmY1ef0UPE4eqFtzE_9S5VN0Zzf6yYSEYzo-kQakvs1KSaI6Xs25AWDMYhvYZK99HV3o1IaZacYCvrhY0BHOe-PACtPK_LbN4hNbbdHxIjOKkJQHFArbJsisdAVWPsFJ7c
description, main features and output and runtime-charts on the back
-FPCp094TL14WZHuL9-BXTn-oEqZweDQx8GC13Wv76IOJhXT6QL1L5KFhvX7IOVcpWPRPzPfkJ8epYVXCj9CmCj-Lb8n3ojFjbgi0DHgeYkacV3y01QROxNqU5UEhTqvpsQZ9sDq
the TK72R has gained a prize, the prestigious RedDot-award
PSo8fu2Wp6PHfUw1KkppGZaxmj66AOp7udV7JJP50gicqNIOndUBv2LKKxZU5y0LFqMYV-6MwjfJYgF-gYK4b5m8n0haGPHX7lfyjCQXPaQkzkAMc_AMeksVl3cn8MYK0WqHpbA7
foam keeps the light and its accessories in place
_A-8bsN3MC2slawjUVz71z00gV41qsD4S04qG60JPQ89tvmb3rtY1SKUde3rDJcstMHNQI9ZzB0NMpLmIv1NLb7NGH2P3mwi1fbTqTTEdx8urJhoii84qRHEroMsuMfYzELH28UG
the contents: ready to go, battery is already inserted
gIO326E9JvvZFjswxVHGXZ_9a3bsaiHWQenKw8c_kqsW3keO6rVtASTdBMgmM32sNYGXiJ8sqkqp0k4X_B-1-SgftKrb8EniMoVowD5KpiC4yyajtg-W3zAsABmbb9vbhE0N6AHj
Impressions:
The TK72R is a large and rather heavy flashlight, but much more compact than its big brothers TK75-2018 and RC40-2016. For your reference: it has about the same dimensions as the LD75C. My first impression is the same as always had when I met a Fenix-product: Very well built, excellent fit and finish. Like most flashlights the TK72R comes in main black color, the second color that we see back around the lenses and the display is matte silver. What I see back on this matte silver is that it's not scratch-free: After some weeks use you can clearly see some “user-traces”. The TK72R has a powerful appearance, thanks to the thick body and the triangular head that has three XHP70 “quad-leds” in it. The light is very stable and can be put down on it tail as on its head without any problem. The body has fine knurling and six slots to ensure good grip. Anodizing and engraving (in grey color) is done well, I couldn’t find any defect here on this powerhouse. Most striking detail on the TK72R is the control panel on the head. It is fixed to the head by some torx-screws and has an OLED screen in the middle of the panel. Below the screen we see three buttons: a larger one and two of the same size above it. Like we saw back at the latest Fenix-lights, the switches are made of metal, which will ensure long life and durability. At the opposite some information engraved: serial number etc. On the third side we see the micro-USB charging and the USB-discharging port, protected by a rubber cover. Special feature here is that the ports have “waterproofing treatment”, which means that the rubber cover isn’t specially needed to prevent it against water, only for dust. A big plus here! Having a look into the triangular head, we see three rather deep but small “orange-peel” reflectors that have perfectly centered XHP70-leds in it. This shows that the quality-control is very good at the Fenix-factory, I couldn’t detect any defect here again. When we “dismantle” the TK72R, we have three parts. Striking detail here is the “symmetrical” tube; it doesn’t matter how you screw it onto the head. Machining and greasing of the threads is done well; inside we see three gold-plated poles for the battery. No springs here to prevent against shocks, but the TK72R feels safe and robust. On the back you can choose out of two loops to add the lanyard. The lanyard is re-designed and feels better to me than the previous versions. Summarizing I can tell you that the fit and finish of the TK72R is like it should be to a light in this class: Excellent done. I could tell you more about the light in this chapter, but let’s have a look now at a selection of pictures that I took. These photos will show you much more about the light and the details!
the king of the TK-series
NjdFxVpnfQWbzrnIuQIqNW1ZcbhdlfE_MWAtynTz4V8rzFSjtS1Tu6RUlNQVvvz9h_r2iruHghxmUTLUKp9ynRzslDodfgjtm31M-48lF964BgCNBjLEDDQMHg9jkxew34t0dUfz
searchlight and powerbank in-one
KK0AA_H_Ju_RxtMle1eLxI2Xq7b_VRtRHBLez3ZKMy0WItkijW7I2EcRddeN40Jgm3LW9CSOoLKsvcTubfIs3SMTBpLvFyQZkuonVRwjE9QrmwVF0UxGaXEVroK863Xq4dXKtGtD
big triangular head with three XHP70’s
KwzI6sKSeMDQmZB7k1cvayNGYnY593Pw_QDRRSI8ZualvJWxbgmWxE3sja7-7wvPH233JhZ96c68YWs5v3hptj53qBDntYXrhfiq8UJZYbEq8UALepEdXa5nCOlt91t2pJRwaA-f
well-constructed
xqJ-uWRg6vQK02WzUkiebj6y-9wzet8o-LKsT1ZM-xfhqpq4qsSLiyKx1AKGe5SuDfoxam-6QZeAppDEqfR01d_fdPKa_ZThCq-rMEy0kV8NY0M7PhMh0vmQCvqi1woqtNzCS6sc
rather heavy but easily to control
Dcixum7Zdt09LPopKmE39rMTrClt08B5huRQ2wTAZkJcLloTUmQuXMUUp7VuRFWVf3xEk9pv7JYiZ1E9WBGxCWiIBi66Hb1ey0iceqq5ylDEbnPdKbYkI7PGMw_EmIgg5SYHfr00
the TK72R has its own design
QpLHO-vvsyE3GZPYWRCZtbOxJ496DRfBoGL6iWCTS0_Y8gwleG9zYnfHILLyrgH_b9QOxaHhP1d8RDnlxIAYdqkXNUz10GGUzGXALAJaNG54MM_dWc8RtWGP7u256JjWzhL7ziuO
small but rather deep reflectors
vGGZ42RXG-3tE91VcLwmNLMWUYdmgwUp1-G29egQ_0HXsYb4ftIN21kLG4DovqtfGDWMDaUMZ4Xfd3RpQSb-OnyhrCYRUOd_suB8rSUTDSr7WB6lKoAOlP_jG-Kn6KX0nksV2BVR
fine knurling and slots to ensure good grip
VdHLfm8HTyX9TcYtFH5zSD5H3T-NDDblhcofokSHyXW1ENkOMxdYXTFL0mPoFwk1yhYSAIA9kR_LqPECO7nqbhmY79O9sUtk0Li9iEmArIIVpJDX9XrAwcrsiOJNNsFMgPVXZ7ij
the cooling-fins; nice design!
z4kYO-rOgBazU_W6tATnRXSkZU0pWVRf0pSAwjxtEFRK7g9lrt9Wz4wCaaA0hTYSJXqEb4ljqG9Hr1GnViJGB2_VoKSNJlgtLQV4Bxi9b0zHJftS3Dvwr3qC2QbwOyTGSR9ApOHw
a cover protects the USB-ports from dust
RzjJokxMV0z8avE-M-rcrX_TYg2Dm6O_6r7JO8opnsrMGM1Nms3D79P2IFFIhryPRGmGzx5i2lR9q1YK91zCCT12zjAVeVrWFNZm5Lk0waldJ41ChIUBK1mFtzvqzHodrgOe9DwC
special feature is that the ports have inner waterproofing treatment
96g5SrDKvH-BQFy1gWDrOqbU8ar7KzRf8pMnBoh0xqUJr2PrNiCqIHyGYD-ttfItbju97YD01N5ADo9VLO61xal01RUWsH29XCdtn132weB651TQuv67huSTHAQlUK1mxM4y4drl
a close up to the head
5OrHeL7EbMuw019rO7T2QVmj0g14vfc7I0JhSKO3AqedZWjM3hmg-6IWa2427emtXwNF1AXs9uva-BHH3xW3-VOP4donr-UEBdDGrAfCf826KRZqRpibNyKNSxFJ-V97a5J-_ccT
big tail, stable standing
S22755FY01Ru7VBIMuzJTJg5C6m-6iGvArCXasKfU8WIW24R3mDF12fXGYP8QMHhJvUJoTF2sMHhD6MLSc2OGdFzXYnDSBb-N4Wepp305UJ47QO_0hJ-lP8aNXrGxXalb0oqqL9J
de TK72R in three parts and the battery
v_bYOdaeArsGeC4AEZXbfsoFCrGamQWJaJqQ31-fM4xoJX7HoB9RFiMqjsx2vPB7atcBbiQh9qXBo-Kh9DUSonOYu8--ZM6RDrAjFL8XZfltqE8tyxDhzXPu4S73sOr9qYoVNHn0
it doesn’t matter how you insert the battery
ahaIIbfngWj5IkBv6ZeszHP5zRHfP1Zr2UcZbil49MvCz91OkYeIZ18fYnUjYvPNvWWfVL1eW06hoY-GBUL1wivXveywwjd8EBQyBH3KJKtCa0Gip0xbEqJU8olVWD6lxQZ_kPK6
a look into the lights’ head
0pZunu6Fj-JMAaMQQNtrHPYk6_Rj4k6tgGxFgqPk0QpaFZmCWOJZ7YdUhNZasU5infVynYhVJ31ysg7VwjWYkFx8TBRRlQ8H71UFuc_TsUBUyQ6UGrT6CNt73DDasR_yvyIzdqqV
keep this in mind, otherwise the light will not work
Ga_l4LeM-gM7RQjD6vhX-F6adOdVa5ox4xYaT7e8T_3qXFcnhMVJZv-i8AUZN9srvlJozgizksCKiaRp5GKsp76VGA15h4DiSVGG9pYyrei9ZFgym13we4HR5P5vPyhkhZ1_DES2
reddot winner
IUXCUU-vl8wemow6Eny4Sq4KpyJyS0YGWeU-edOPWGAKjfSWhe9bNlV4ww5ST8C85wLTyOR6Q4jn37Vce-8bPSZ8soED1jfHqztYsMGlo0kJSgHJTom_qROpmSByv4VY8M16FXnn
comes with powerful charger
w8wWHkrK-ExUZXXn-LdglbJ-cgVGJ-qXAUkVzRwsRYOFhi6o5Vo-asep02WekwkQRlcYncGbhyvVz8A2qrQHRuisd7WuHl40dIInjdpW0hn1fF9ebFB-tAScqUqY9rD_QlOjznm4
the redesigned lanyard
jZTXapccCXdEd-Pdyrf5kaFPUvri_rC_-w16vPOCMPlElTgskYkb-FdRQrUlKUFdztKl9Y9ud7XOwu6N1f9oDRuXCIoUT0NQAENuHNavXb3ff3NReTPvnHrBrBRrgSoThk-isS18
after turning on, the brands’ name lights up for short time
VFgJcf0OR0RMJgwaaTmRBfSaHacKO0n5GpH3ZbUWyBEiVDK3_v9kFBS9igq_ftuTbMeSBSzPVDVCcRqZnJOfczNNph9ELhftdJl40L0UT6EuaRD4O8zD22DjW8Tym7nWmCoODVVO
the display informs about remaining power and lumens continuously
y0qRIdwVGUMe9dgx9jsHNpaQwgfOD7DBTl8LWDqJ8bbLjyv-bjKak2NVFR4KXWxn_epLmkxPd3_lZ6u0sJLXN9uRKlUgGREaSs0WTBcfsD3NMAJchcNC2_ULbkYhEaj-jszwGN1j
if the padlock is shown, the light is locked
z9rPhdRV94GIDsDUmhfIg2jJR-lpCgEfQPpVYC7W5EPszRT-DvpnORgc36b2x4bezM4qskFm5adSmDqnDx3Ls1f1-qN-XjjnYUdQmBTY53mgWQOxHS9FODWT8KCsp75SzsCnLCTS
the icon for strobe
E2gSlhA88IOyUp9S-Vx6Mk-iPncjezDwC48pEHO2pan9JDS4w_O__mIoKyGYp1k61HZAjHzqWjOZPLhLxJTCu8soQlvXDZAUaJBKon-VTIaXfVLg14QXppi9vjYACIvtMDk82-Ty
the sturdy pouch
peLEDG3h0dokBWkaTR_VJ15Ld56KGB2O7Ta0f3017kru1y2Xzo90mp4hQSKCGkWV8dm9Mz1RybMlTyDkcFNZhInCsBcpg8reTpmLd22uf-5q9_tTu2BWcaAKmab1uAm4Q8TZT4KT
the TK72R fits well
LTCEO5vf67LE08CfhLXKidCd9bN5wsiVROnirBZZRgYjJJkQm9L2ATiCQphD43TcwpUSESLbQY9j7ADYowNR4NK0DA30NR9NUQBhH1cXbn_Zgpx1NcJCqSbUFzMSgMpokPcuuGky
charging the light
ds5_ermrAvMaIYU9C286LSUex0V01t3QCe2lDwuqoAmaLXy_xlH6Y8ZK3-SxoOJFFyOZNKy5PsJ2To23fineqkixrAP2q_eSF_nohGw4RcMrMj3QbIQeAThKSxW6bQAHxH22d8gA
using the TK72R as a power source
aOg4Sl1_8zOF1qDm1tX3AMCX8JeiaG7Ndd5psRnhXry0T21E4CgFMESvnmKrQ7GSXMz38THrUlygMjcN7WU3V3dBSkdQKino17WAhRukdUQM2HMWTbW1MYQgrZg8fi1zCOnjXhN0
during charging, the light can only run on lowest level
s2UAHBXRElofxYnZxJZbkkqsyXdwE8X4jfd5v8ELwEtHyEwJk6-aM4O-iYMnNcAjRKne697GBS2Iq6OmAS8oRveOREDg4HXeDY-bFnliQXg5adt_a-13YZzu1lZ0v3Bse0wzygak
mounted on a belt, good option during longer trips
EppLMSAysrqW5cddG_1zQM0-gjFjvot44ExHNcZDLcSe3xrSNf5Ic1xKHd6xQo8VPvTFkyYDGeKuMjj0R1aSVZnmtX7FN4mZC0yoQqx4zYXI8MRjpmIlpOk0VRmsBbNWaR3zTVD3
compared to the Fenix LD60, that Fenix released a couple of years ago
bmLr0uN2YU7Z8HJ9JGUWIPT0_7DG_2OsT_AidnC1IWrwUWKy3vXLb-XNdYCXEzLEDoa_fSaW5UyAZJpDA9rnh8u6ZvsZBqFtecbgXunJfuu1N1EMKN3l2XDfoL79lrVymEa2NMLt
same size, but the output has increased more than three times!
BnNMu1d1F9c7LecVScMtn3xJ6OPm3012yR9Q3YSvzqs6pSVgj-NUvMsHVKMRb3ggm6ERvVQhSldaAUGXIe9EVt-8wqZz7ARIfRjggH5DIsJ7u9QOSsV4V3SBTewa0r2AWigpmKn1
the TK72R next to the previous output king of Fenix, the RC40-2016
u6vCV2Ypav1dx0ZRMH1zOeJq6-IkAhpO13TpdzkYjF2LyFjS6DvEin6-bcbjXRGVsnv4v30qOu_rkLlpkFKsyygqIfPWRkqc5WI6FvL3qbXoiOCqHds1BFQH37_JAxMLyUiCTZB1
more leds to the RC40-2016, but less lumens
YYcNgZBCqLQz4A4e0IDpyotxOSUA5XHrgCgESfkmLUixACcSzPGQSwu0zXzlDrb-sdlumn7lxVSQOAqiBX-qSXwnMjEFE6vnrEbaH2uHa4UmxFLtDnSbIweDyxl6wFXbaVasik1w
the TK72R on a cold day
neIV2c_VNUvYuQlbWfr4EFHDg6lE8pTCCcXLHLpA5pqRCo30ovKnHcoGOnREpxy6Y3DIGcM9xFSB2SZ12C9q1HAgnVxglvNF0SXDOXwCWiyxVs-l322x8r0qUmQTnsimGoXP_xPK
the light stands lower temperatures without problems
wxomkTvXZFZjszK0K-n2l_UOPw-aS8S8WreUoU4R6r6quXK9ZLNn8dh6VcQJTmKEZqM4BD7DMUjtq4dv1Lx4WcyHom3TCtuVbSEwRk_XVkvz4LDP_AySReCwkrxKOsBrShUtZUZ7
some gear: TK72R, tactical pen T5 and Ruike P105-K knife
B-u4jLZhQwsdoa05AfICfHp1lhaLTRB13Ym9Tk_ZEujbD2Y303QGAGINQ2AEMb24vjujQGrAxtXxALd4ukvCsdaRb197S51FBU9FZ46R-ePMnfOPCeDN6UJCnN0-OEprdSBw1YO0
the LEDS are perfectly centered
wKByIT-z2TpRRaNINcQ06A_U5ciFA31J8SHUyBQOvDLyZ7A5d5hS7Qogi9x-zMjfVuyJht-i11PcZNt4-e3KhvxR0sU_a05xMMXWpaT_SfbedFMdjK7Gm_kFDCWsIINuFNQsQQEX
User interface:
Like you’ve see already on the pics, the TK72R is a large and robust light. But, thanks to its length, it can be carried in your coat pocket if you want. Best way for longer time is to use the holster that can be fixed on your belt. The body is quite thick, same dimensions as other lights that run on four 18650’s, but the grip is good. The triangular head prevents against accidentally slipping out of your hand, the control panel can be reached easily by your thumb.
Charging the light is an easy job with the provided charger. I’d recommend to charge the light by day, because a full load of the cells takes about 4,5 to 6 hours. During the charging, the actual voltage is continuously at the screen. Same for discharging: You can easily check the remaining power. For your reference: Fully charging a cell phone (in my case a depleted Samsung S6) takes about 20% of the battery. So I could recharge five times my cell phone with a full TK72R. A plus to the RC40-2016: you don’t need to press a button to activate the discharging anymore, it starts directly when you connect a device to the flashlight. Good to have a powerful flashlight and high-capacity power bank in one! A plus to light that have a built-in powersource is that the battery can be replaced; you have also the opportunity to purchase a spare-battery if you use a flashlight for many hours non-stop.
Back to how the TK72R works! As I showed you, the light has a control-panel with three buttons. The buttons have a good pressure-point; but I would like to see them different in shape and a bit bigger in size. The bigger (middle) button is to turn the TK72R on (in last used mode) or off. Press and hold for about a second to turn on/off. The left and right switches above are designed for mode selecting. Special feature of these buttons is that these are also “shortcuts”. If the light is in standby, you can start directly at 200 lumens (left switch) or 5000 lumens (right switch). Turning on these direct modes works the same as with the main switch, to turn off you can only use the middle/main button. The unique feature of the TK72R is that it’s possible to pick every output mode (by steps of 100 lumens) between 100 and 9000 lumens. You can “tune” the output by little steps (100 lumens per click) through shorts clicks on the plus or minus button, or by big steps (1000 lumens per step) by pressing and holding one of the buttons for about a second. I never met a flashlight before that has so many fixed output levels! Because this torch is designed for big tasks, the direct low modes starts at a rather bright 200 lumens. Little high to me, and although it has a lower of 100 lumens, I’d prefer a mode of less than 5 lumens on this light. Some applications at night don’t need more light, and the light would have better runtimes too. The light has direct-turbo too, that only can be activated with the light on. Click the main switch to enter turbo, click again to go back to the last used mode. There’s also strobe, that has two frequencies. This mode is extreme blinding, beware to try this out indoors! A flash-icon is visible on the screen. No SOS-mode can be found on this light. The light is prevented against overheating: When the temperature of the light get above 65 degrees, the light will decrease by steps of 1000 lumens until 2500 lumens is reached. If the battery gets low, the light will step down to 1000 lumens until the battery protection turns it completely off. The light can be prevented against accidentally turning-on: three quick clicks on the main button will (de)activate this (good) function. This is indicated by a padlock-symbol on the screen. Overall this light works like other Fenix-torches: easy and effective. Nice solution that the light has steps of 100 and 1000 lumens. I miss momentary and turbo from off, although the direct mode to 5000 lumens is strong enough to start with.
In practice, the light works fine. It’s a bit heavy when you carry it in your hand for longer times. In highest modes, the light will get warm soon. For longer use, the output of around 4000-6000 lumens is a very good one to me. The TK72R will run a long time in these modes without getting overheated. This is the advantage of a big flashlight against a smaller one that can reach this output only in turbo mode. In contrast to other lights that are equipped with XHP70, the TK72R has a less floody beam. This is also because of the small en deep reflectors. I’ll show you more about the output and the beam later in this review.
Modes:
I can be short here, because the TK72R has only two main modes: LOWEST and HIGHEST. Between the two (range of 100 to 9000 lumens) you can choose every level by steps of 100 or 1000 lumens. So, the spacing is very good… Like I mentioned earlier, a lower level is desired. Three direct modes here: direct-LOW(200 lumens), instant-HIGH (5000 lumens) and direct-TURBO (9000 lumens). One special mode here: STROBE, this is an instant-mode. The TK72R has LOW-VOLTAGE warning, but the actual voltage is continuously displayed on the OLED-screen. The torch has an electronic LOCK-OUT mode. Most modes that are needed are there.
Size comparison:
I showed you the TK72R earlier next to some Fenix-brothers, but now I’ll show you the flashlight next to another powerhouse, the Olight X7R Marauder. Both are in the same price-class and powered by the same leds too. Later in this review, in the beamshots-section, I’ll show you more about these two!
the Fenix TK72R and the Olight X7R
JTx2Q2WCtVt7PJDeyPUjaN1dDAsQwDqjQmWkIB8KVYfyBCYPVVq2zy1gZS5GFj3zxP1m2lF9kqmfDRNaCtgmWUBXnU71dSGPxUbFSMA536DiQk_EzQ0Fe6c_6Tohp7xB0EX8OWW7
R0GaCysBT-0_7BxTduxXEPDMp5Kqt0fTSB_hMkQzzXew8suXxIf2N_409ZK1ZovAoTKsoa-7FY7SbA3e3C5LxRDTLcsm8iWjVkHL36CMqwjYyl6c9J8r7mCUIqCCXvFeseDvkuYb
ZQtfiCWUUaAac3MaV7LlVp0Yk0bSY2RwSz01pSPbRGSQQT10x3bqCwJI3qJCJfGYFRXzJv8GKhqYRY7lFfwbe0JbAkJelgsOJPmcydvnn-Z0CpWwH2bpc6UkV8rA70aIuM3bRzzB
both smooth reflectors, but difference in diameter
8YuvSdmF7DaFCi-3erN0QK3I0jvgKEo9YWgyXmfwIgg9pSByHUtWYpKt9XMsRfiksktZA2C7XQS6isAAQNhPy94GnEtAXVWR3oOWloXpT0kvx_SsxZxIpFABMy2M1Tx4U5aBjyx8
both powered by the same XHP70 leds
oly24IkuMDbpPct_Y72J9ekkaWcdo5UQWgB08lMurQ-G8JdBxLkjTYeppAdkM1E0wpdx2irq8c1hayFfmWo5oAUbHKxoD7h2CngIsBr4tSr40HsNQWxMhSLpTsg1qsQMyinINmMD
the backs: the Fenix TK72R and the Olight X7R
R6Kh-yY2ESAAR-bu3mkOTpeEDOtTLLcdVVsSYNF4GEgibc1N6li_BOvabIoldttyCR5rfDKFKRsk_aca_oXslKvVObCtLN6tAFzda4KmNeMkvuAzH1RteHzgbPhnHhG2tKCkZ0NI
Tint:
The tint of the TK72R is coolwhite, and is surprising good in the whole profile. Have a look at the picture below to see what I mean: The X7R shows yellow/green in the corona and spill, the TK72R has the better color here.
dx3yXt0LKWLOxovrGKr9IiljRIKncBLwnBJg0wtdWI267euahzNE7M3-gw6we7SAFmLPDVuVMgpTmyXvZzDMXqsMfUxhNeAsrOxz5TPBUnINpGUdJi5OmzPCC_OSIY00ymGy0LFX
Beamprofile:
The three quad-led give a big, broad beam to the TK72R. A big and equal hotspot, medium corona and not that much spill. So we can’t expect a for reaching beam, but a large area illuminated at about 50-150 meters away. The TK72R really creates a wall of light! The beam is clean and free of defects, neither PWM could be detected.
Time for a couple of beamshots now! Starting indoors on a white wall. Because the TK72R has around 90 output levels, I chose for the options “lower-modes” and “higher-modes”. Lower means 100 up to 1000 lumens (steps of 100); higher means 1000 to 9000 lumens (steps of 1000). Mostly GIF’s here, otherwise it will take a lot of space to show them all. Distance to the wall about 1 meter.
Camera settings: ISO100, WB daylight, F/2.7, 1/125 sec, 35mm
the lower modes on a white wall
the higher modes on a white wall
Going outdoors now! First location is a road, a wall at right side and some trees at left. I always use the same settings for my beamshots, so this time some pictures will look little overexposed. This is because the big output of the TK72R. Again two GIF’s, first the lower and after that the higher modes.
Camera settings: ISO100, WB daylight, F/2.7, 4 sec, 35mm
the lower modes shown at the road
the higher modes shown at the road
Same road, tripod some further away. Here’s the TK72R against the X7R Marauder. The Olight has clearly more flood. And keep in mind that the X7R should have 3000 lumens more than the TK72R.
the TK72R versus the Olight X7R Marauder, both on highest level
Another location: A field and a treeline at the left. Compared against the X7R, you can see that the TK72R lights up more trees, the X7R has clearly more flood.
Let’s compare the TK72R now to the previous Fenix output-king, the RC40-2016. This big torch still has an almost unbeatable combination of output and range, but the TK72R has also a wide beam that reaches a good distance.
the TK72R versus the Fenix RC40-2016, both on highest level
Now the TK72R and the X7R together! With both lights you can light up a very large area!
the TK72R and the X7R both on highest output-level
I picked another location to show the higher levels of the TK72R. A field at the left, a ditch in the middle and a wall at right side. The humidity was rather high here, so at highest modes, you’ll see some more reflections. Here we go!
a GIF of the higher levels of the TK72R
Let’s see the TK72R now next to another 9000-lumens torch, the Olight X7 Marauder. The TK72R has better output at medium to higher distance, the X7 has great flood.
the Fenix TK72R against the Olight X7 Marauder, both on highest level
Same location, compared now to the X7R Marauder. This light has the same profile as the X7, but some more output.
the Fenix TK72R against the Olight X7R Marauder, both on highest level
Conclusion:
As seen on earlier products of this manufacturer, the TK72R is also a very well constructed and finished flashlight. I’m sure that it will last for many years. I like the design. The light is a bit heavy to carry for longer times but comes with a good holster. The brightness is impressive, the tint very good. The powerbank-function works easy, the TK72R can charge a device for several times without problems. For me, the buttons may be some larger and different in shape; if that, it's easier to find the right one in the dark. The shortcuts to low and medium level is a nice find, together with the instant turbo you can choose your desired level very quick. I don't know or many user will use the “fine-tuning” on this light, but it can be a handy feature. I miss momentary on, and would like to see also a better and more economical low. An upgrade to USB-C type would shorten the charging job. I detected also that a tripod mount is missing: a pity, because the light is very well suited for photography.
If you're looking for a sturdy and durable big torch for different applications, that sometimes need more or less light, the TK72R is a very good pick. Comforting thought is that is also a powerful spare battery for your phone. Also recommended for Fenix-fans who like to have the opportunity to carry a lumens monster in your coat pocket. The light is much more compact than the TK75-2018 and the previous lumens-king RC40-2016.
Special thanks to Fenixlight and Knivesandtools for providing me the TK72R for testing!
the TK72 on highest level
v_KTNl1nArubkZYfTIEKMxzj6GiDc8tcFasTVQuBHg9LVWI8efQi7v257VZTpc5UOJAJs-_iLRM1F4hA2QDFLWySBUjakZ6vCcqg_vAFZhV-OQGBkb0NKsNpp3MjRiSGBeWgIURS
F3eBKdD87kogNewhfLVtFyvIafqZvuWkUkiO3h_0u9B0xHBW4yGH1_n0Zd5YaGWXAP_4s9wyDprsnHeUOXOi3WSsWrU2R4tSm59zFoMgfYTZKo-SRSqtGMY3SaVyKuablgbm6Rvn
aginthelaw
Well-known member
NJ, USA
Can the light be discharged to 0% with no effect on the battery pack? I assume there’s still juice left in the batteries so they won’t suffer damage
kalantan
Member
Mine is only a year old with very light use. The battery never gets to 100% charge as per the light's indicator. Stays at 85% fro days after charging up. After a few weeks in my pack, the battery shows at 59% when first turned on. Anyone else have this issue?
torretto7542
New member
Try the following: Charge the light completely. Discharge it, until it shows 00%. Recharge it again. I guess it has to be calibrated. Mine never got charged over 92%. First 100%, after turning it on, 92%. After I did this, it charges nearly up to 98 - 100%.
Please answer me, if this was successful.
