ro.ma.
- Joined
- Dec 3, 2012
- Messages
- 222
Armytek WIZARD C2 Pro Nichia (warm light) was sent to me directly from Armytekstore.de for review.
For the description, technical data of the house and the purchase: https://www.armytekstore.de/flashlight/ … -usb-warm/
The Online Manual: https://www.armytekstore.de/index.php?d … ent_id=237
A 15% coupon code "Bright15" is available on the website: https://www.armytekstore.de/
I have always particularly appreciated the light quality of Armytek products, especially in the Warm versions. I am therefore happy, thanks to Armytekstore.de, to try the Wizard C2 Pro Nichia model, an update of the Wizard Pro Nichia model, popular among lovers of high-quality light.
The Wizard C2 Pro version, with Nichia LEDs, has an almost perfect color reproduction and is therefore particularly recommended for use in situations where natural color reproduction of illuminated objects is required; for example, photo and video shooting or in the work field (painting and polishing, color coding of wires, etc.).
DESCRIPTION AND TECHNICAL DATA:
Armytek WIZARD C2 Pro Nichia is a multifunction torch with a white light front lighting system (Warm) powered by a Li-ion battery 18650 3500 mAh (included) with a maximum autonomy of 6.5 months (Firefly mode).
WIZARD C2 Pro Nichia has a compact design with an anti-abrasive matte finish without rough knurling, managed by a convenient side button. The Armytek headlamp has a TIR optics with a beam that covers from 70° to 120° (hotspot and spill) and, in this "warm" version, it has a Nichia LED with high CRI (>90), with a color temperature of 4500K, a maximum light output of 1600 lumens and is rechargeable via the magnetic port, located under the cap.
WIZARD C2 Pro Nichia has a water protection rating of IP68 (10m for 2 hours) with resistance to falls of up to 10 meters and is equipped with an active temperature control system.
It is sold with some accessories included in the package and a head support (band) to be used, in a simple way and with one hand, as a torch also having a powerful built-in rear magnet.
WIZARD C2 Pro Nichia is suitable for everyday indoor use or for outdoor activities (running, cycling, sports, fishing, hunting, car maintenance and assistance etc.) with multiple installation variants and optional accessories for mounting on sports equipment and is compatible with AHM series helmet mounts for industrial work and mountaineering.
Main Features:
WIZARD C2 Pro Nichia is sold in the classic Armytek cardboard box. The main features of the flashlight are specified on it, some of which are not present in the small manual supplied. Opening the box we find inside the torch with the included accessories which are: Steel clip, nylon holster, 2 x spare O-Rings, 18650 Li-ion battery (3500 mAh), magnetic-USB charging cable, head band with support and user manual (quick guide).
The HEADBAND.
In the sales package we find the head band with the support where we will put the WIZARD C2 Pro Nichia for use as a headlamp. Excellent quality and adjustment of the elastic band complete with upper band and excellent plastic support where we will attach the torch.
C2 PRO NICHIA is installed and removed, in its support, easily and rotates 180° safely thanks to a quick release silicone ring that provides additional secure fastening.
Wizard C2 Pro Nichia is a beautiful and functional flashlight. It is built in lightweight and shock-resistant aircraft aluminum with new springs for better protection and battery contact. Even in this version, the matte anodization is sensitive to scratches, or to the insertion of the supplied Clip, but to the touch the impression is excellent; it does not slip despite the smooth body and does not roll.
It holds well and the weight on the head, even with the battery inserted, is not excessive (115 gr). Thanks to the tail and flat head it is possible to put it upright (tail standing) or with the head upside down.
Starting from the head we note the TIR optical system that provides a wide and uniform beam (hotspot/spill: 70°:120°) without distinct hot spots and sharp edges, tempered glass and anti-reflective coating surrounded by a protruding steel bezel for better protection of the optics. Also highlighted are the horizontal cooling fins and the ever-numerous writings.
WIZARD C2 Pro Nichia has a Nichia LED (should be the 144AR) with high CRI (>90) and a color temperature of 4500K. With this configuration the WIZARD C2 Pro Nichia has a maximum power of 1600 lumens and reaches, with its beam, a maximum distance of 113 meters.
To the left of the projector we find the yellow power button, large, surrounded by a metal circle. The electronic switch has a loud click but also a soft and comfortable pressure. It is the only button on the WIZARD C2 Pro Nichia for managing the torch (UI).
Under the button we find a multicolored Status indicator LED (temperature, battery level and status).
In the Arnytek WIZARD C2 Pro Nichia the only unscrewable part is the tail cap on which we find numerous writings.
The powerful built-in magnet in the rear cap allows the torch to be anchored stably on iron objects. Wizard C2 Pro Nichia has complete protection against short circuits even in case of contact between the magnetic connector and metal objects.
Unscrewing the tailcap we notice a large spring plated to the negative and a smaller spring to the positive. The threads arrive well greased, furthermore the WIZARD C2 Pro Nichia is equipped with two O-rings for water tightness and is certified by Armytek IP68 (10m for 2 hours). The magnetic connector is robust and water resistant; the torch continues to work even after immersion at a depth of 10 meters.
The resistance to falling is 10 meters.
In the package we find a 18650 lithium ion battery without protection circuit with high discharge current (13 A) and capacity of 3500mAh. With this configuration we have the possibility of using any 18650 battery, flat or button top, protected or unprotected.
Armytek WIZARD C2 Pro Nichia provides complete protection against short circuit even in case of contact between magnetic connector and metal objects and allows the physical blocking of the torch by unscrewing the tailcap by ¼ to avoid involuntary ignitions.
On the back of the tail cap, magnetized, there is the charging connector for the torch.
To recharge the battery you need to unscrew the tailcap by 1/4 turn and make the magnetic charger adhere to the tailcap.
To recharge the supplied battery it took me about 3 hours and 40 minutes. If the cell is higher than 4.0 V, charging does not start (the charging status remains green). Always in my tests, the full charge stops at 4.19 V.
Armytek Wizard C2 Pro Nichia along with other headlamps.
From left: Armytek Wizard C2 PRO NICHIA, Armytek TIARA C1, Nitecore HC68, Zebralight H604c e Acebeam H15.
USER INTERFACE (UI) AND LEVELS:
WIZARD C2 Pro Nichia has a total of 11 light modes. The operation is not easy but it becomes so with a little practice. By default we have 6 light modes with the possibility of switching to the professional advanced operation with 11 modes. The spacing of the available modes is very good covering the available brightness well from 0.1 lumens to 1600 lumens.
General type (default): Firefly1, Firefly2, Main modes, Turbo mode (last used in Advanced, Turbo2 by default).
Advanced type: [1] – Firefly modes, [2] – Main modes, [3] – Turbo modes, [4] – Strobe modes.
In the WIZARD C2 Pro Nichia it is possible to add or remove the strobe mode. To do this, simply unscrew the tailcap 1/4 while the flashlight is off, press the button and tighten the tailcap while holding the button down and then unscrew it again.
WIZARD C2 Pro Nichia has active temperature control. When the temperature of the flashlight approaches +58 °С, the brightness drops to the safe value, allowing the flashlight to avoid overheating for a long time.
When the battery level is low (approximately <25% of the nominal value) the LED will flash 2 times. In case of low battery, the flashes will repeat after 30 sec from switching on. At critical level the light output decreases to Firefly mode.
In OFF state:
1 click to activate the last used mode.
Press and hold to activate Firefly mode, holding the button down will cycle through the modes of the chosen light. Release to select.
In ON state:
1 click: to turn the flashlight off.
Press and hold: to start cycling through the modes of the chosen light. Release to select.
2 clicks: to activate Turbo mode from any mode. Second double click will return to the last used mode.
Firefly. Press and hold the button in OFF state to go to Firefly mode. Release to select. Holding the button down will start the sequence and cycle through the main modes.
Main. A short click from OFF state will activate the main mode if it was the last used mode.
Cycle through modes. In ON state press and hold the button in any mode. The modes will cycle through (Main1, Main2, Turbo and Strobe). Release to select.
Auto-memory. After power off, the last used mode is remembered for quick access the next time power on.
GENERAL TYPE
In OFF state
1 click: to activate the last used mode.
Press and hold: to start scrolling through the Firefly modes. Release to select. Holding the button will start scrolling through the main modes.
In ON state
1 click: to turn off the flashlight.
Press and hold: to start scrolling through the main modes from any mode. In Firefly1, scrolling through the main modes begins after scrolling through the Firefly modes. Release to select.
2 clicks: to activate Turbo mode from any mode. The second double click returns the last used mode.
ADVANCED TYPE
In OFF state:
1 click: to turn on the last used mode.
Press and hold: to turn on Firefly1 mode [Section 1]. Holding the button will start
to scroll through the modes: Firefly1 - Firefly2 - Firefly3 - Main1 - Main2 - Main3 - Turbo1.
In ON state:
1 click: To turn off the flashlight.
Press and hold: To start scrolling through the modes of the relevant section.
The same in OFF and ON states:
2 clicks: To turn on the main mode [Section 2]. Another double click will toggle between the modes chosen in [Section 1] and [Section 2].
3 clicks: To turn on the Turbo mode [Section 3].
4 clicks: To turn on the Strobe mode [Section 4].
To switch between modes:
Unscrew the rear cap 1/4 while the torch is off, press the button and tighten the rear cap
while holding the button.
BEAM and RUNTIME:
The beam of the WIZARD C2 Pro Nichia, thanks also to the TIR lens, does not present surprises being without strange aberrations or color rings. The tone is neutral (4500K) very pleasing to the eye with a beam, of an alluvial nature, that covers the walk well reaching low and medium distances. The specifications claim a hotspot of 70 degrees and a lateral exit of 120 degrees; the light beam is "smeared" without an evident demarcation between spot and spill. I did not notice PWM or flickering in any of the available modes.
In the photo below the three photos were taken indoors using three different headlamps (ISO 500 F/2.8 1/60 sec.).
The same sequence also outdoors. The color of the Armytek Wizard C2 Pro Nichia beam faithfully reproduces the color of the illuminated part unlike the Acebeam H15 with predominant yellowish and the Zebralight H604c which suffers from the low throw being the beam completely flooded.
Using the OPPLE Light Master Pro, a fairly accurate device even if not calibrated, I measured the CCT color temperature value, the Ra color rendering index and the flicker measurement if present. These are the data reported by the test:
TURBO2 - Color temperature (K): 4720 - Color rendering index (Ra): 93.5 - Duv= -0.0005
TURBO1 - Color temperature (K): 4603 - Color rendering index (Ra): 94.1 - Duv= 0.0007
MAIN3 - Color temperature (K): 4521 - Color rendering index (Ra): 94.6 - Duv= 0.0014
MAIN2 - Color temperature (K): 4481 - Color rendering index (Ra): 95 - Duv= 0.0014
MAIN1 - Color temperature (K): 4436 - Color rendering index (Ra): 95.1 - Duv= 0.0012
Flicker Index (Risk): No risk for the tested brightnesses.
In the table below are some values in candela (cd) taken with my Luxmeter after 30 seconds from switching on.
Runtime:
I would like to point out that the values expressed in the graphs should be taken, above all, as a reference because they were made with means and environmental conditions different from those used in the laboratory. The measurement made with the Luxmeter reports the values in Candela (cd) and not the expressed brightness.
As you can see from the graph below, the WIZARD C2 Pro Nichia is well adjusted and the runtime times roughly reflect those declared by Armytek.
In TURBO2 (1600 lm), at the start, the brightness increases for about 30 seconds and then begins a decline that becomes sudden after a minute from the start. After a constant output for over 160 minutes from the start, other drops in brightness occur in sequence as the battery approaches exhaustion. After more than 260 minutes from the start, the brightness drops to the lowest level (Firefly1) for a few hours.
In TURBO1 (750 lm) there is a slow and constant decrease at the start, up to 11 minutes from the start, before suddenly decreasing in brightness. Even in this level, after a constant output for about 160 minutes from the start, there are other drops in brightness in sequence as the battery approaches exhaustion.
In MAIN3 mode (250 lm) the discharge curve is constant from the start for about 5 hours and 30 minutes before starting the decrease.
The switch flashes red when about 3V remains. In my tests, at the end of the test, the battery marked 2.8V, remembering however that the Wizard C2 Pro Nichia could still remain on in Firefly1 for a few hours.
The first 20 minutes:
VIDEO Unboxing and Use
Armytek Wizard C2 Pro Nichia Unboxing and Use
CONCLUSIONS:
Armytek Wizard C2 Pro Nichia is an excellent headlamp with a high color rendering light beam that returns real colors; it is well adjusted with 11 light levels available with different Moonlight modes which are now rare to find. The sales package is complete and I would like to underline that the Wizard C2 Pro Nichia can easily be powered with other 18650 format batteries (10A).
The user interface, with two distinct user interfaces, is particular but easy to manage especially in advanced use. I hope in the future for a USB-C charging port which is now a standard adopted by many. Highly recommended.
Thanks for reading the review.
------ MY YOUTUBE CHANNEL ------------------------------------------------
Main Features:
The HEADBAND.
In OFF state:
In ON state:
GENERAL TYPE
In OFF state
In ON state
ADVANCED TYPE
In OFF state:
In ON state:
BEAM and RUNTIME:
Runtime:
CONCLUSIONS:
