I did a review of 3 different shake lights (i have copied the reviews in one after the other so I apologize in advance for duplicate info)
Nightstar II pictured center with Viatek left and PowerPlus Woodpecker right
Product: PowerPlus Woodpecker
Cost: Around AU$20 on ebay
Details/Features:
Waterproof
Doesn't need batteries
Duel recharging coils
Lanyard hole
Constant on and flashing modes
Torch/Flashlight Review Checkpoints
Output Max: Not specified, Decent amount for a shake light, probably a little more than 12 lumens. Significantly more throw than my other two shake lights
Runtime Max: 20 minutes according to the box (after 60 seconds of shaking). NiMH storage. I actually had it run for over 45 minutes
Tailstanding: No
Knurling: None
Beam Profile: See image:
Beam Tint: See image, slight blue tint
Reliability so far and predicted: Flawless thus far, and I believe it will continue to be flawless though I am a little concerned about durability of the switch
Waterproof: According to the packet it is waterproof to 2 meters. haven't actually tested it.
Ease of use: easy to use, 2 modes of operation, flick the switch to the left to get constant on, flick to the right to get flashing mode. Middle is off.
General size: Micro/Keychain/EDC-Pocket Carry/Regular Handheld Carry/Very Big
Of my 3 shake lights, this one definitely throws the furthest. With its duel coil charging system it does also appear to be the fastest to charge. The beam is a little messy with lots of rings (as per beam shot above) but for utilitarian purposes it really doesn't matter that much. Unlike my other two this light has an NiMH battery for energy storage instead of the capacitor. Because I believe the capacitor should be longer lasting in the long run I would have preferred if this light had capacitor storage.
The switch on this one is not a magnetic type like the other two shake lights I own, but a mechanical switch which will probably be less reliable, and is also a possible point for water ingress (though I didn't have any which I did a quick bucket test). That said, the switch does not feel flimsy or anything, and it certainly hasnt failed me yet (though I haven't used it extensively either).
If this light had capacitor storage and the magnetic switch like the Nightstar II I think it would be the perfect shake light, however, even without I still think its a very good option.
Stealing from the review of the Nightstar now:
As a word of caution, shake lights have very strong magnets so you have to be a little careful about what you do with them. You may not want to throw one in your backpack next to your expensive laptop or compass.
Product Rating
8 Stars out of 10
Product:Nightstar II shake light
Cost: Around AU$40 on ebay
Details/Features:
Waterproof to 200ft
Lanyard hole
Output Max: Not specified, usable amount (i would guess around 10 lumens) for indoor use but you wont be lighting up a trail
Runtime Max: 20 minutes according to the box (after 30 seconds of shaking). Capacitor storage
Tailstanding: Yes
Knurling: None
Beam Tint: See image, blue green color, not the best
Waterproof: According to the packet it is waterproof to 200ft. I have tested it in a bucket and swimming and had no issues.
Ease of use: Very easy to use, shake it then turn it on (switch on the side)
Of my 3 shake lights, this one certainly feels like the most durable and it does have a usable output. The only downside is that it was twice the price of the other two. Unlike the other two it has magnets at each end of the "shake tube" so it shakes much more quietly and smoothly than the others. It also has a magnetic switch (as does the Viatek) which is supposed to be ultra reliable. I haven't broken it yet.
The light also features a glow in the dark switch which can be handy, though typically it doesn't stay "glowing" for long enough to really be useful (ie, by the time you have forgotten where you left it in the dark it has gone dim)
I have a friend with one of the older models, that has seen quite a lot of use and is several years old now and its still going strong.
This light has noticeably less throw than the "PowerPlus Woodpecker" but the overall light output is only marginally less.
If your looking for a light that will still be working when you have been out in the woods for 20 years living off snared rabbits and blackberries after the zombie apocalypse I think this is the light for you. If reliable and durability is less important, then i'm tempted to recommend the Woodpecker instead because of the increased throw and lower cost.
Product Rating
8 Stars out of 10
Product: Viatek Shake Light
Details/Features:
Waterproof (untested by me)
9.5 inches long
Lanyard hole
Output Max: Not specified, but terrible, probably less than 3 lumen
Runtime Max: On my example... about 30 seconds. Uses an inbuilt capacitor for storage.
Tailstanding: No
Knurling: None
Beam Tint: See image, blue color, unpleasant
Reliability so far and predicted: First one I ordered arrived non functioning, this one sort of works see more details below.
Waterproof: According to the packet it is however I have not tested it.
Of my 3 shake lights, this is by far and away the worst. My first one arrived dead, it would illuminate while shaking but go completely out as soon as I stopped shaking. I requested a replacement which was sent (so I am happy with the seller, just not the light) to me straight away. On arrival the replacement worked, but while the box says "30 seconds of shaking provides 20 minute of light" I have found that 10 minutes of shaking gives about 30 seconds of light (ok, maybe a slight exaggeration, but 2 minutes would not be). The light output from this is easy the worst of the 3.
Additionally the switch can be unreliable, sometimes you have to turn it off and turn it back on again to make it work.
Also, due to design quite a bit of light comes out the back of the head causing glare which is not particularly desirable when your trying to see where you are going with the minimal amount of light it puts out as it is.
Definitely not a recommended product. See my reviews on the PowerPlus Woodpecker and Nightstar II if your in the market for a shake light.
Product Rating
1 Stars out of 10
Details/Features:
Waterproof
Lanyard hole
Tailstanding: No
Knurling: None
Product Rating
8 Stars out of 10
Details/Features:
Waterproof to 200ft
Lanyard hole
Tailstanding: Yes
Knurling: None
Product Rating
8 Stars out of 10
Details/Features:
9.5 inches long
Lanyard hole
Tailstanding: No
Knurling: None
Product Rating
1 Stars out of 10
